Snapped camblet Q?
Old Jul 17, 2005 | 05:52 PM
Oranoco's Avatar
Oranoco
Default Snapped camblet Q?
Mate picked up a lovely tidy Escort TD yesterday and on the way back from Kent today it snapped its timing belt.
What are the chances of getting away with just fitting a new belt? What possible damage can/could I expect?
Don't mean to sound like a thicko but I have no experience with diesels
In advance
Old Jul 17, 2005 | 05:56 PM
dave cos4x4's Avatar
dave cos4x4
Probably bent a few valves etc...
Have to take the head off and check the lot of them.
I had this go on one i had,about Ł170 in a garage to put right.
that was a cheapish garage btw.
Dave.
Old Jul 17, 2005 | 05:57 PM
SteveB's Avatar
SteveB
Starts with F and ends in UCKED..... quite commonly snap the cam as well as bending the valves
Old Jul 17, 2005 | 05:58 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Bent valves most probably tbh.
I would guess the pistons will be marked, but should be useable. Just so you know, CI engines run a much tighter belt too, because of the increased compression. And dont start it up with the airfilter off. Never seen it, but heard reports that they can pull rags and other crap off worksurfaces into the engine! Greater forces!
Old Jul 17, 2005 | 06:39 PM
Oranoco's Avatar
Oranoco
Well I have had a fight to get the remains of the old belt out put a 19mm spanner on the bottom pulley and it wasn't too hard to turn at all.
Old Jul 17, 2005 | 06:42 PM
CraigN's Avatar
CraigN
if youve turned the bottom pulley with no cambelt on youve probably done even more damage
you will need to take head off to check valves
Old Jul 17, 2005 | 06:43 PM
TrickyDicky's Avatar
TrickyDicky
i've never known a ford 1.8 diesel not bend the valves when the belt has gone.
depending on speed it will snap the cam-may not be visible till you unbolt all the carriers, and can smash the buckets as well.
definetely head off mate, it is an interference engine.
hth
Tricky
Old Jul 17, 2005 | 06:45 PM
morcheen's Avatar
morcheen
the valves can also goose neck in the guides,they might look ok but become very stiff ,a second hand head would be cheaper.
Old Jul 17, 2005 | 06:46 PM
TrickyDicky
once a valves bent its bent, no amount of turning will do it any further damage-apart from if you try it at cranking speed etc the oil pump isn't working with no belt on!
Tricky
900ss's Avatar
900ss
RWD Racer
Bust cam n prob head damage
Old Jul 17, 2005 | 06:47 PM
Dragon's Avatar
Dragon
I've done a couple of these with snapped belts, both of which were at low speed and were repairable, ie: snapped/bent valves and guides so new heads on both. Apparently they don't often survive so was lucky in both cases.
Old Jul 17, 2005 | 06:52 PM
dave cos4x4
Have to get the price of a used full head then.
Be easier to put a full head on.
Dave.
Old Jul 17, 2005 | 06:55 PM
TrickyDicky
non turbo heads are exactly the same as turbo so don't phone any breaker and ask for turbo head as the price will go up by Ł20.
hth
Tricky
Old Jul 17, 2005 | 06:58 PM
Oranoco's Avatar
Oranoco
Cheers for the input guys
Looks like I'm going to be a busy chap over this week then. I was so looking forward to just chilling out
Old Jul 17, 2005 | 07:00 PM
NEO™ŽŠ's Avatar
NEO™ŽŠ
oh yus bent most valves n dependant on speed might have snapped cam too
Old Jul 17, 2005 | 09:08 PM
Oranoco's Avatar
Oranoco
Was on the motorway doing about 75-80 when it let go I've just been told. I'm expecting the worst
Old Jul 17, 2005 | 09:29 PM
TrickyDicky
you say he only picked it up yesterday in original post, unless hes bought it from the block i'd approach vendor wether private or trade about remuneration for repairs.
Tricky
Old Jul 17, 2005 | 09:33 PM
900ss's Avatar
900ss
RWD Racer
Says who?
Ł100 is Ł100, td or otherwise
GUZZLER's Avatar
GUZZLER
i done one on a non-turbo at 80mph, 7 bent valves was allit done, no head damage, although as said above some do snap cams or break the cam caps.
use pattern parts with a genuine belt & tensionor kit, that shouldn't be to bad.
pabloXR
Sep 21, 2015 12:42 PM
dojj
Aug 25, 2015 06:56 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
