wastegate actuator
Old Jul 17, 2005 | 12:14 PM
DRUE1's Avatar
DRUE1
Default wastegate actuator
just need some help.how would you know your wastegate actuator is fooooked? are they easy to pull out or are they hard.because mine i can move it in and out very easy
Old Jul 17, 2005 | 12:17 PM
Wazzzer's Avatar
Wazzzer
sounds like you need a new one then...
Old Jul 17, 2005 | 12:20 PM
DRUE1's Avatar
DRUE1
cheers for the quick responce m8y
Old Jul 17, 2005 | 12:27 PM
Physio's Avatar
Physio
To be 100% sure it has to be pressure tested to see if it's leaking air etc.
Old Jul 17, 2005 | 12:38 PM
DRUE1's Avatar
DRUE1
when i drive the car i can hear the air leaking through the wastegate actuator. its not a nice sound when cold ive even turned the arm 4 turns in to see if it will close it but no joy and its so easy to move the bar out
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
rs_jim
Sep 19, 2015 08:41 PM
