FAO Lee R21Turbo
Lee,
My MSN keeps dropping out and disappearing, so the questions I were going to ask were:
Does your turbo already have a threaded connector sticking proud?
Does the block have a connector sticking out of it at all?
Pics if you could would be very handy!
LOL..wondered where you'd gone....
Turbo has threaded connection - standard cossie size.
Block has no connector sticking out - its female.
This pic is the old feed pipe (top) and the new one - both identical size - the aeroquip fitting is the same as an 044 pump as discussed.
Anything else you need just holler!!
Currently half of it is a braided pipe - which looks to be the next size up from a standard cossie item - but then it goes to a thinner metal pipe for the rest of it.
I'm sure that if the whole pipe was the same bore as a cossie item it would be fine - bear in mind that the smallest item its going to encounter is the adaptor into the actual turbo itself.
I'm sure if its good enough for a cossie its good enough for a lowly Reno! LOL!
155lee
Aug 14, 2015 11:21 AM
