Checking Cossie rear beam
Jul 15, 2005 | 06:42 PM
How can i measure the rear beam/trailing arms to check if they're bent?
I know somethings bent for sure, but not which part
Jul 15, 2005 | 06:47 PM
Hi John
i don't think your beam wil be bent , your trailing arms mighted be fooked
just get a couple of traling arms they don't have to 2wd get any and just weld your anti roll bar brackets off your old arms on to your new ones
marco
Jul 15, 2005 | 07:01 PM
John
or the only to check it properly for a 100% is take your beam off and put it on a jig that will tell you if it's bent or not
Marco
Jul 15, 2005 | 07:02 PM
You could get checked out at a wheel alignment place.
they will at least tell you how bent it is,if it is, and which side.
Still, not as bent as mine.
Dave.
Jul 15, 2005 | 07:21 PM
Dave.
Dave
how you doing bud, you ok now
hows things sorry to see that mate , feel a bit sorry for you mate
Marco
Jul 15, 2005 | 07:30 PM
Alright Marco thanks.
Will be back,may take a bit but will be back.
Dave.
Jul 15, 2005 | 08:01 PM
Re: Checking Cossie rear beam
Jul 15, 2005 | 08:13 PM
Quote:
Could it be the Driver mate?
Quite possible if the car was bright orange
Jul 15, 2005 | 08:19 PM
Jul 15, 2005 | 08:57 PM
Jul 15, 2005 | 11:33 PM
Jul 15, 2005 | 11:35 PM
Jul 15, 2005 | 11:38 PM
Might just do that, gotta go see Karl anyway
You got any spare front drive hubs Brom? Need a pair desperate
Jul 15, 2005 | 11:44 PM
sorry mate got no 3door hubs at all
whats wrong with yours
Jul 15, 2005 | 11:54 PM
Warped
Same as a Saph tho' mate
Jul 15, 2005 | 11:56 PM
no jono there not same as a saff
3 door have taperd joint and castle nut bottom ball joint
i got loads of saff ones in stock
saff ones have a pinch bolt design to lock in the bottom ball joint
Jul 15, 2005 | 11:58 PM
Drive hubs Brom, not complete hubs, the bit the wheel bolts on to
Jul 16, 2005 | 12:01 AM
Jul 16, 2005 | 12:06 AM
Jul 16, 2005 | 07:13 AM
Jul 16, 2005 | 07:15 AM
Quote:
Originally Posted by dingy
Oct 9, 2015 07:38 PM
155lee
Sep 14, 2015 07:37 PM
FlashRS
Sep 14, 2015 12:36 PM
Bosch
Aug 23, 2015 12:31 PM
dal3door
Aug 13, 2015 06:55 AM
