Heated screen on mk5 Escorts....
Just pondering fitting a new screen into my Onion (mk5 Escort jobbie)
It's only a normal one, but wondering if I should fit a heated one while I can get one.... What do I connect it up to tho?
Is the loom already installed and just a case of finding it and plugging in? Or do I need a sub loom and relay/fuse etc?
Dont wanna fit a heated one to find I can't connect it up and then have one (purely from the little lines are annoying, I could suffer em if they worked, but if it ain't gonna work I don't want em, and just get a top tint one instead)
think it has a seperate loom geez. and it runs off a 25 amp fuse, not sure what number it is off the top of my head.
not 100% sure if you would have the loom, without looking for it, best best is to take vents out and have feel for any extra loom behind the dash, but id guess if you havent got heated screens then id say you havent got the loom.....
hope that helps in some way.
cossie09
Sep 10, 2015 06:56 PM
