[SEARCH FUNCTION] back, but...
At the moment only allow to search thru posts since 5 weeks.
It will start from now on and every topic made will now be indexed.
I will continue improving it, but you can now use it as it is.
Watched topics and WAP pf are also on their way, i will soon have finished them
I don't know if i worded it correctly but i meant that every topic made since 5 weeks is present in it, and all the ones made from now on will be too.
HTH
The rest is as i said
Originally Posted by Petrucci
erm, it's there and has never left, Andy...
Could not obtain topic ids
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'GROUP BY p.topic_id' at line 5
SELECT p.topic_id FROM phpbb_posts p WHERE p.post_id IN (246986, 246984, 289983, 292514, 237957, 266119, 261988, 261950, 217225, 217282, 217374, 175351, 245975, 245971, 241940, 192044, 192043, 191351, 305525, 246973, 245861, 245841, 245815, 245880, 247217, 247205, 243484, 308226, 245518, 238090, 172804, 172841, 173387, 245159, 186962, 305566, 240537, 250731, 250727, 250706
DEBUG MODE
It`s not woking for me this came up
real
DEBUG MODE
SELECT p.topic_id FROM phpbb_posts p WHERE p.post_id IN (1853909, 1853987, 1854002, 1854039, 1854118, 1854141, 1854198, 1854565, 1854883, 1854893, 1855276, 1855280, 1855287, 1855296, 1855596, 1855805, 1848473, 1855922, 1856047, 1856094, 1820191, 1857731, 1858226, 1858837, 1859019, 1853429, 1860128, 1860352, 1861112, 1861287, 1861564, 1861582, 1861668, 1861692, 1861725, 1861787, 1862192, 1862206, 1862223, 1862315, 1862326, 1862387, 1862397, 1862473, 1862485, 1862509, 1862777, 1862801, 1862889, 1863184, 1863657, 1863818, 1863837, 1863867, 1864635, 1864664, 1864699, 1865136, 1865138, 1865153, 1865411, 1865534, 1865603, 1866066, 1867488, 1867600, 1867815, 1868021, 1868089, 1868323, 1868473, 1868503, 1868508, 1868521, 1868555, 1868637, 1868690, 1869476, 1869607, 1869928, 1870226, 1870279, 1870316, 1870362, 1870390, 1870584, 1870612, 1870652, 1871210, 1871234, 1871461, 1871475, 1871507, 1871626, 1871815, 1871821, 1871835, 1872101, 1872107, 1872220, 1872275, 1872456, 1872877, 1873026, 1873042, 1873094, 1873112, 1873156, 1873252, 1873262, 1873266, 1873476, 1873490, 1873534, 1873565, 1873619, 1873837, 1873972, 1874152, 1874343, 1874416, 1874472, 1874589, 1874675, 1874744, 1874786, 1874826, 1874870, 1875000, 1875006, 1875026, 1875060, 1875074, 1875079, 1875080, 1875149, 1875165, 1875219, 1875310, 1875405, 1875601, 1875747, 1876021, 1876066, 1876128, 1876297, 1876449, 1876533, 1876546, 1876653, 1876739, 1876767, 1876785, 1876898, 1877019, 1877095, 1877113, 1877324, 1877744, 1877772, 1877776, 1878011, 1878101, 1878139, 1878207, 1878253, 1878298, 1878313, 1878441, 1878497, 1878897, 1879241, 1879307, 1879343, 1879371, 1879421, 1879464, 1879520, 1879537, 1879587, 1879615, 1879659, 1879743, 1879760, 1879847, 1879912, 1879917, 1879921, 1879960, 1879999, 1880035, 1880040, 1880083, 1880120, 1880295, 1880323, 1880529, 1880930, 1880918, 1880942, 1880957, 1880987, 1881129, 1881486, 1881527, 1881602, 1882000, 1882064, 1882152, 1882157, 1882212, 1882696, 1882748, 1878280, 1883258, 1883278, 1883526, 1883622, 1883745, 1883882, 1884117, 1884128) AND p.forum_id NOT IN (37, 45, 55, 60, 66) GROUP BY p.topic_id GROUP BY p.topic_id
Line : 443
File : /home/passionf/www/forum/search.php
real
DEBUG MODE
Line : 443
DEBUG MODE
SELECT p.topic_id FROM phpbb_posts p WHERE p.post_id IN (1854277) AND p.forum_id NOT IN (37, 45, 55, 60, 66) GROUP BY p.topic_id GROUP BY p.topic_id
Line : 443
DEBUG MODE
Line : 443
Pet:
Just tried a normal search for the word "blah"
DEBUG MODE
SELECT p.topic_id FROM phpbb_posts p WHERE p.post_id IN (1854240, 1857685, 1858473, 1863669, 1867224, 1875193, 1875704, 1882599, 1884189) AND p.forum_id NOT IN (37, 45, 55, 60, 66) GROUP BY p.topic_id GROUP BY p.topic_id
Line : 443
Too many GROUP BY's
DEBUG MODE
Line : 443
Too many GROUP BY's
Pet, I get debug thingy if I use
VIEW MY POSTS thingy
Search for a keyword (example I used "turbo")
and SEARCH FOR AUTHOR
everytime I got the DEBUG message, could not obtain ID blah blah blah
VIEW YOUR POSTS has not worked for me in many months
This is the error I got doing a search for "RS1800"
Might help.
DEBUG MODE
SELECT p.topic_id FROM phpbb_posts p WHERE p.post_id IN (1855320, 1855478, 1855490, 1855498, 1855505, 1855521, 1855919, 1851544, 1858448, 1859418, 1865269, 1870305, 1332836, 1878538, 1879551) AND p.forum_id NOT IN (56, 37, 45, 51, 55, 54, 60, 66, 68) GROUP BY p.topic_id GROUP BY p.topic_id
Line : 443
Might help.
DEBUG MODE
Line : 443
e.g.
https://passionford.com/forum/search...=Mr.Manchester
