Changing Cossie doors, help needed ;)
Old Jul 12, 2005 | 07:04 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Default Changing Cossie doors, help needed ;)
I,ve got another door to go on my 500, but with the cage in it's almost impossible to get to the nuts on the hinge, is it possible to knock the pins out?
Old Jul 12, 2005 | 07:07 PM
markk's Avatar
markk
the honge pins seize in solid m8, even using the special tool that sykes pickavant do mine would not move , the only way is to heat them up and then try again - good luck
Old Jul 12, 2005 | 08:09 PM
cossiecrew's Avatar
cossiecrew
right bastard job matey can you deffo not get to the bolts then cus if you can but its a struggle i bet its way easier than takin the pins out
Old Jul 13, 2005 | 07:45 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i took the pins out of my 1988 sapph with no problem whatsoever. give it a go, nothing to lose.
Old Jul 13, 2005 | 07:55 AM
Sticky.'s Avatar
Sticky.
Get a angle grinder on it then put a set of lambo doors on it
ginner
13
Aug 30, 2015 08:40 AM
wheelwizardrefurbs
Aug 15, 2015 05:54 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
no1trancefan
Aug 4, 2015 12:48 PM
