URGENT!! Escort mk3 & 4 Loom Clips.
Old Jul 12, 2005 | 03:48 PM
BillyCabrio's Avatar
BillyCabrio
Default URGENT!! Escort mk3 & 4 Loom Clips.
I need a picture (or a finis code) for the loom clips that go along the underside lip in front of the heater box.
The ones i have (now for sale in the Escort Rs Turbo room) dont fit and i think are completely wrong
Cheers in advance.
Old Jul 12, 2005 | 05:01 PM
BillyCabrio
Ka-Boing
Old Jul 12, 2005 | 05:08 PM
xr4x4rs's Avatar
xr4x4rs
there the same as all the other engine clips bar the two near the battery
one is instead of it being pushed into a hole its slots on
and the other is white that does the same but only holds your strters wires
if that helps
i can get a pic if ya want but may take a bit of time to upload it
Old Jul 12, 2005 | 05:13 PM
BillyCabrio
xr4x4rs, Piccies would be sweet mate, i dont think their the same fella as i've tried the ones that i bought and they wont clip in the holes and stay there while being upside down
Photos of all the clips would be good mate
Old Jul 12, 2005 | 05:24 PM
xr4x4rs's Avatar
xr4x4rs
thats cause there not supose to be upside down
but you do have the correct ones for the engine bay
these are the only two that are different to the rest and you only need 1 of each
hope this helps
where the white one is the black one is just a bit nxt to it
Old Jul 12, 2005 | 05:31 PM
BillyCabrio
Do these push onto the metal 'shelf' that the airbox bolts to?
Is the black bit on the left of this photo the heater box?
And is this photo taken from behind the inlet manifold towards the battery?
Old Jul 12, 2005 | 05:56 PM
NUTS RuS's Avatar
NUTS RuS
Urgent.....
Old Jul 12, 2005 | 06:46 PM
BillyCabrio
Urgent enough for me!
Old Jul 12, 2005 | 08:22 PM
xr4x4rs's Avatar
xr4x4rs
the balck one slides on to the lip where the heater box sits on the battery side where the white clip is
on the fuse box side up unyil the middle you should have holes for the normal engine bay clips
then it will be this black one then a hole for the white one if that helps
yes that is the heater box on the left and yes it is behind the inlet
andyrs1600i
Apr 29, 2026 03:21 PM
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
