Which pipe is the one for the turbo's water cooling- see pic
Please help me im just fitting my new turbo and wasnt sure where the pipes go for the water cooling as they were not on the car when i took it off.
Any pictures or help will be more than appritiated, as you can see in the picture ther is a pipe which is blanked off and the other returns to the header tank.
Cheers in advance
[/img]
Cheers in advance
[/img]
So where does the water return too?? The other pipe which is next to it goes into the header tank.
I thought there was only one pipe, but when i looked again i realised there was two pipes.
the one with the bolt in is meant to be like it
it is an air bleed hose leave it.
the one closest the turbo is the turbo water feed pipe, the turbo water return goes over the cam cover and back to the header tank
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
track.focus'd
Aug 12, 2015 05:53 PM
