General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i can find out from work if you want, wouldn't be able to post it until i get home later though. Dont know why you want it though as they've been unavailable for years now
as ^^, you can't buy 2wd one new anymore from ford. they sell you a 4x4 one, and then an adaptor piece to make your small 2wd turbo water return pipe big enough to fit the 4x4 tank. (or you make one yourself)
Is the adaptor included when I order a 2wd header tank or will I have to mention this to the spares department ie does the adaptor have its own part number?
the adaptor is not included with the 4x4 tank. it has it's own part number, as4x4 owners do not need it. but if you order the 2wd tank, the system will tell them to order a 4x4 tank + adaptor piece.
