Clutch problem/recommendtions
Old Jul 11, 2005 | 01:08 PM
Westy's Avatar
Westy
Default Clutch problem/recommendtions
just recently, Occasionally I have trouble getting into gear whilst caining it..
Like I say, its not always the case, sometimes fine.. but as of Friday, seems somethings up
Its an AP 4 paddle jobby, which to be honest has done quite a few everyday miles..
Is it just worn do you think? Doesnt seem to be slipping
Also, if it is fooked, any recommendations, or just go with another AP one?
Ta
Old Jul 11, 2005 | 01:17 PM
B19-TRB's Avatar
B19-TRB
Possibly a enigne/gearbox mount!?
Old Jul 11, 2005 | 01:22 PM
Westy's Avatar
Westy
yeah good thinking batman
See, it goes soft sometimes, then I press it again, and its back to its usual paddle stiffness
Makes me think that the ACTUAL clutch could be fine still
Old Jul 11, 2005 | 01:24 PM
B19-TRB's Avatar
B19-TRB
it goes soft
I can sale ya some tablets to cure that!
The fact that it only does it sometimes may sugest gearbox mount!
they the original 1s!?
Old Jul 11, 2005 | 01:25 PM
Is it hydraulic?
Old Jul 11, 2005 | 01:28 PM
Westy's Avatar
Westy
probably standard ones Lewis..
Chip - I would know mate Its just an uprated RST jobby.. Noticed there is a 6 paddle available now..
Old Jul 11, 2005 | 01:33 PM
B19-TRB's Avatar
B19-TRB
No its not chipper its cable!
Old Jul 11, 2005 | 01:54 PM
Rules out leaky cylinder etc as the reason for it going spongy then!
Old Jul 11, 2005 | 02:01 PM
B19-TRB's Avatar
B19-TRB
would a weak/stretched cable cause the above chip!?
Old Jul 11, 2005 | 02:06 PM
Westy's Avatar
Westy
I put a new cable on when we done the clutch..
Wondering like yourslef, could just be stretched and slack??
Old Jul 11, 2005 | 03:02 PM
mart.rs's Avatar
mart.rs
possibly could be the cable,or the pressure plate may be sticking to the flywheel occaisionlly??
Old Jul 11, 2005 | 03:07 PM
John Laverick's Avatar
John Laverick
Westy what power you running as the CP-2000 clutch kits are the nuts up to a certian power level.
I sometimes have trouble engaging gears when the car gets really hot
Old Jul 11, 2005 | 03:12 PM
B19-TRB's Avatar
B19-TRB
John thats cable m8!
Slevae the cable with a heat wrap sleeve!
cured the probs i had with the balck mamba!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
