Hot starting
on the starter motros u have a small(brown i think) wire concted to it by a lil plastic push on plug!
cut that plug on & attach a nice new ring connector! then put thta over the connection on the starter motor & screw a nut on to it to hold it on!
walla!
walla!
awrite al.the guys above are rite.u can wrap your exhaust wae heat wrap at the starter to stop it getting cooked.is your fan on in the petrol station when you put the ignition on.mines wouldnt start when like that and i put a 60 amp per hour battery in instead of 44 amp and it starts no problem now.
If u need to buy a new motor get 1 from a xr2!
its about 1/2 the size which takes it miles away form the zorst!
the heat shields r absolute bollox! did fook all on mine!
i fitted the xr2 starter & it was exclelent!
Does anyone have the part number for the heat shield and the xr2 starter as i'm having the exact same problem with mines. Hopefully i can still buy them both brand new to solve this ongoing problem
Melly
Melly
Which one would be the best buy the starter or the heat shield. Can you still buy both new from Ford. Found a part number 1644016 Ł14.47 for the heat shield but changing the starter for a new one now saves me doing it later if necessary
Melly
Melly
Originally Posted by addiction
if you dont have the starter motor heat shield on you will have problems when hot!! you can still get them from ford
also i have a spare starter motor if you wanna part with some cash
Originally Posted by B19-TRB
u can probably get a good 2md hand starter for about Ł20!
I'd go for the starter myself!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WD1V
If it is the correct one then i'm sure a few peeps could get in on it as the guy seems to have a few.
Melly
When my S1 starter started to loose it when hot (bumping it of the petrol station forecourt sounds very familiar or having to wait 15 min), I swapped it for a recon Escort 1.8D starter and no problem ever since.
thats what i was going to mention was try a diesel starter as if you use an xr2i one im not sure if it is able to turn over the engine or there might be a chance you could fook the ring gear!
