24V cosworth lump in a mk 2 escort ??????
Old Jul 10, 2005 | 05:57 PM
!mouse-oxford!'s Avatar
!mouse-oxford!
Default 24V cosworth lump in a mk 2 escort ??????
i want to put the 24v granada cosworth engine into my 2.1 pinto'd mk2 escort and was pondering on a few things:
1.i want to change the car to manual! what flywheel will i need to source and what clutch would anyone recomend to use?
2.as the engine is still currently in the granada and being an auto am i going to run into any managment problems when removing and converting to manual as i was going to use everything i needed directly from the donor car!!!!
3.all the shocks brakes etc have already been upgraded with willwood 4 pots and 2.8capri front legs etc and totaly polybushed throughout so its up to the job could u see any problems with doing this?
4th and finaly with refrence to the sump will i get away with the standard one or will i have to wait and find out???? modifiying the sump wouldnt b a problem as i have a freind whos a engineer should any problems arise!!! any help will be gratefully received!!!
Old Dec 10, 2005 | 08:30 PM
Taps's Avatar
Taps
If your still looking for answer's Try here www.fordpower-uk.co.uk
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Aug 14, 2015 07:29 AM
