AFR on over run, wots best/ safe?
Old Jul 9, 2005 | 07:12 PM
Fiecos Dan's Avatar
Fiecos Dan
Default AFR on over run, wots best/ safe?
just wonderin wots best under engine brake.
is it ok to run mega lean?
Old Jul 9, 2005 | 07:14 PM
Graceland's Avatar
Graceland
Team HOTHOT!
generally, there is no fuel going in on overrun, apart from around the 4000rpm mark for piston cooling, then nothing again untill 1200 for idle - or thereabouts
Old Jul 9, 2005 | 11:37 PM
Really does vary a lot from car to car, many manufacturers boost cut totally for the sake of economy, others piss fuel in at a huge rate for cooling.
Old Jul 10, 2005 | 09:07 AM
Fiecos Dan's Avatar
Fiecos Dan
but is it safe to run no fuel on over run, on a big bhp cossie?
Old Jul 12, 2005 | 05:53 PM
Fiecos Dan's Avatar
Fiecos Dan
bttt
Old Jul 12, 2005 | 05:55 PM
ECU Monitor Enthusiast
yes - no fuel=no combustion=no extra temperature
Old Jul 12, 2005 | 06:19 PM
markk's Avatar
markk
mine has fueling on overun purely because if we cut it , then activate the als i get no effect till i hit 2000rpm and below !
Old Jul 12, 2005 | 06:21 PM
Fiecos Dan's Avatar
Fiecos Dan
cheers simon.
so its all boll-cks about puttin fuel in on ver run to keep cool.
Old Jul 12, 2005 | 07:10 PM
No - Thats just a slow (old technology) ecu over fuelling because
as you shut the throttle the L6/L8 software takes time to recognise
this and still fuels for boost that has disapeared.
(This is pressure measurement integration/averaging for you tech heads.)
takes about 2-3 seconds on some weber ecu types/software versions
OR otherwise its just plain and simple bad mapping !!!!
Old Jul 12, 2005 | 09:20 PM
Neil S's Avatar
Neil S
Simon, I thought that the objective was to remove heat from the high loads prior to overrun rather than to manage cylinder temps during over run
Or am I totally wrong?
Could be an interesting post this
Neil.
Old Jul 12, 2005 | 09:22 PM
CharlieSaff's Avatar
CharlieSaff
My car was mapped by Karl and it has over-run fuel after coming off of boost to cool the pistons!
And I'm VERY glad it does! For piece of mind if nothing else!
Old Jul 12, 2005 | 09:27 PM
Rick's Avatar
Rick
Always makes me laugh this - whats cooler, rich combustion or no combustion....
Old Jul 12, 2005 | 09:30 PM
Neil,
IMO, this is an explanation given by tuners to shut people up to explain crap mapping
and/or a complete missunderstanding of how an ecu works.
This situation typically affects modified weber ecu's that run over 25 psi boost
and usually ALL cars that run over 2 bar boost on a 3 bar map sensor.
The ecu has no choice but to "guess" fuel at this point.
No one likes thier car smoking and excess unburned fuel causes bore wash and fouls the plugs.
For example, if the car is flat out what is cooling it ??? - The cooling system of course !!!!!!
If the "overrun over fuelling myth" was true this means you are only supposed to run the car flat out for a few seconds then let it cool down !!!
Clearly this scenario is not desiried/true !
When flat out or mid range boost/high revs, an ecu needs to average the map readings to stabilise fuel delivery properly.
This averaging has the effect of have a rubber band on the input.
I.E, if you stop one end, the other end still moves until its out of energy.
This typically is more noticableon older OEM ecu's as they use older slower microprocessor and analog inputs.
However, cars running ALS do this deliberately but that really is a completely seperate issue.
Hope thats clear.
Any tuners care to add a comment to this ???
Old Jul 12, 2005 | 09:31 PM
Neil S's Avatar
Neil S
Cheers Simon!
So basically its caused by the time taken for the high MAP values to filter out of the time averaging period of the fuel calc's
Neil.
Old Jul 12, 2005 | 09:34 PM
Neil S's Avatar
Neil S
Surely combustion still takes place even on a very lean overrun Rick!
So what's cooler - rich combustion or lean combustion?
Old Jul 12, 2005 | 09:35 PM
Having said all that, there is no doubt unburned fuel will cool a cylinder quicker than NO fuel but...
If the pistons are that hot when do you know they need cooling ???
When it melts of course.
IMO it is a myth this is any good as the only way it could be effective is you knew the car was running too lean for its application
and knew exactly when to back off !!!
IF a car is mapped correctly, cylinder temperatures will NEVER be an issue !!!
Old Jul 12, 2005 | 09:39 PM
Neil S's Avatar
Neil S
This place needs more tech posts like this
Neil.
Old Jul 12, 2005 | 09:43 PM
AlexF's Avatar
AlexF
Rich is cooler than lean....
No fuel is no combustion but theres no cooling from the incoming fuel either.
Alex
Neil S,
I agree and prefer such discussions ..... but most people are more interested in dirt dishing/shit stirring etc...
Old Jul 12, 2005 | 09:46 PM
Neil S's Avatar
Neil S
Yeah I know, I was just baiting Rick!
Simon - get posting then I love reading this kind of stuff
Neil.
J871yhk,
No combustion is cooler that some wether its rich or lean !!!
Why waste fuel on cooling pistons that should not be too hot in the first place.
Trouble is, people will always want the most power possible pushing everthing to the limit.
What would you prefer a safe cool engine mapped correctly or an engine that might blow up after 30 seconds boost if you dont back off !!!!
Its like locking the door after the horse has bolted
Old Jul 12, 2005 | 09:49 PM
AlexF's Avatar
AlexF
but its fun!
alex
Old Jul 12, 2005 | 11:12 PM
Fiecos Dan's Avatar
Fiecos Dan
thats sorts my issue out.
as on over run, my mapper has stopped all fuel, but i then heard (from dingy) he had a engine melt on over run due to no fuel bein put in. looks like it most of melted just b4 over run.
Old Jul 12, 2005 | 11:38 PM
mark_J's Avatar
mark_J
Can someone please explain then why on rolling roads, once a run has been made the operator starts giving the car revs as it slows down?
I always thought it was to dump fuel in?
Old Jul 13, 2005 | 05:29 AM
ballin's Avatar
ballin
learnt a lot from this one great post and info Simon I was always under the impression you should fuel on over-run but maybe I won't bother now!
mark J, I dont know but I assume on a rolling road where there is little resistance and less cooling the engine has the potential to get a lot hotter, hence the additional cooling needed?
Old Jul 13, 2005 | 05:10 PM
Fiecos Dan's Avatar
Fiecos Dan
also i guess on rr they blip the throttle, to keep the oil pressure up, to keep turbo and bore cooler.
Old Jul 13, 2005 | 06:20 PM
Pectel's Avatar
Pectel
J871yhk,
absolutely correct
Old Jul 13, 2005 | 07:14 PM
GARETH T's Avatar
GARETH T
i do agree with simon, but something to think about
F1 cars overfueled on overrun
Old Jul 13, 2005 | 07:26 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Interesting.
BUT then again I like flames on over-run so kinda xcheering for the "fuel is good" side on this one, lol
I dont know either way
Old Jul 13, 2005 | 07:36 PM
M Brian's Avatar
M Brian
F1 cars overfueled on overrun :oops:
what revs do they run and how quick does the system need to respond to give no fuel?
are we talking absolute ideals here or not?
you are trying to get the most out of your set up and pushing the limits of boost/detonation temps etc....
is it SAFER to fuel on overrun in terms of running lean etc?
or is it down to the driver aswell....
say you are doing top speed attempt - you reach your limit for distance... you brake and back all the way off the throttle what happens?
Rab's Avatar
Rab
Fucking superstar........
Flames rule, but so does having an engine that lasts longer than a bright idea in the house of commons.
Old Jul 13, 2005 | 07:43 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Im confusesd too...
ZERO fuel on the overrun? Wouldnt that just be a non-running engine? No fuel means no exhaust that means no noise soon as you let off the throttle wouldnt it?
Never heard a car like that
I dont dispute fuel can be used to cool a cylinder BUT there is STILL combustion creating heat !!!!
(Assuming the spark is still active of course)
No combustion = NO HEAT !
As I said before, why waste fuel cooling a cylinder that shouldnt need cooling if the engine is mapped correctly.
So, lets suppose this "cooling" is being done deliberately....
You are driving up the road flat out...when do you know the cylinders "need" cooling ?
5 seconds, 10 seconds, 1 minute, 10 minutes ????
The answer = when it melts a piston because it hasnt been mapped properly or caused by an external fault.
Surprised the expert tuners are not adding their 2 pence worth .....
Old Jul 13, 2005 | 07:44 PM
Steve, all modern cars cut the fuel on overun to save fuel !!!
Noise is still created as air is still being moved under pressure of the cylinder compression
Old Jul 13, 2005 | 07:46 PM
GARETH T's Avatar
GARETH T
im not sure what revs they was doing back then im sure the system was more than fast enough too notice a massive change in throttle angle
petrol do absorb heat alot faster than air does,,,but i agree with what simon is saying in that hopefully your cooling systems (both the water and oil) are up too the job of cooling your engine without the need to run fuel which i is only really getting on overrun (not much use when flat out for cooling then )
Old Jul 13, 2005 | 07:47 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Yea i understand that some noise would still be there, but disdnt think itd be anything like the normal noise in the slightest
But fair enough
Old Jul 13, 2005 | 07:48 PM
GARETH T's Avatar
GARETH T
think i was a little slow there simon
Old Jul 13, 2005 | 07:51 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
what about a slight amount of water on the overrun?
know some WRCs run direct port water inj, making that possible
Old Jul 13, 2005 | 07:52 PM
Its been a mandatory EU requirement to do this on all new cars since 1992 !!
So the esc cos (unless modified and decel fuel cut function turned off) does this !
Old Jul 13, 2005 | 07:54 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
RS1600i's had it too i think!
