need the hieght of a 17inch rim and a 18inch rim
Old Jul 9, 2005 | 06:02 PM
the strut brace's Avatar
the strut brace
Default need the hieght of a 17inch rim and a 18inch rim
i need my car raised a bit due to the fookin bumper being to low, if i put some 18'' wheels on it how much will it raise the car i.e. what hieght is a 17 inch rim and tyre and what hieght is a 18 inch rim and tyre and what tyre would i need to use on a saff with 18's
Old Jul 9, 2005 | 06:21 PM
philc's Avatar
philc
all depends on the side profile of the tyre
Old Jul 9, 2005 | 06:23 PM
the strut brace
yeah , i take it there is a std size tyre that you use when puttin 18's on a saff though, appaerntly 215/35/18
Old Jul 9, 2005 | 06:24 PM
philc's Avatar
philc
what size tyres do you use now
Old Jul 9, 2005 | 06:26 PM
the strut brace
i have a 205/40/17 but i assume i am goin to use 215/35/18 and seeing as i need to raise the car i thought the height diffence might be enough to do it but i dont know what the height diffence is
Old Jul 9, 2005 | 06:28 PM
philc's Avatar
philc
approx 12mm higher from your current ride when using 18's in that tyre size. however that is assuming full tread depth on both.
Old Jul 9, 2005 | 06:33 PM
the strut brace
cheers buddy, well my fronts are nearly done atm so with new tyres on the 18's i should be raised about 12mm with the new wheels and tyres and another 5mm coz my tyres are worn very low at the front , so approx 17mm altoghter then, cheers matey, thats a big help, dont suppose i would get away with 215/40/18's would i , you dont know the hieght i would gain if i could get away with the 40 profile instead of the 35 do you
Old Jul 9, 2005 | 06:52 PM
philc's Avatar
philc
that would raise it 35mm but would they actaully fit?
Old Jul 9, 2005 | 07:02 PM
the strut brace
no idea probably not
Old Jul 9, 2005 | 07:09 PM
DOO's Avatar
DOO
225/35 18 top to bottom mine is 600mm
Old Jul 9, 2005 | 07:11 PM
the strut brace
cheers doo but hang on there a minut , 225/25's never heard of them before, how much are those tyres are they a total coont for ride quality, you not mean 35 profile?
Old Jul 9, 2005 | 07:14 PM
DOO's Avatar
DOO
change it now
Old Jul 9, 2005 | 07:21 PM
the strut brace
i was gonna say you have to do owt to get 225's on? arch wise?
Old Jul 9, 2005 | 07:30 PM
DOO's Avatar
DOO
My Archs where all ready rolled mate but i think you have to get them done with 225. may get away with rolling on 215
Old Jul 9, 2005 | 07:37 PM
Cam's Avatar
Cam
http://www.chris-longhurst.com/carbi...yre_bible.html
Old Jul 9, 2005 | 07:48 PM
the strut brace
doo a couple of quick question for you if ya dont mind
what offset and size are your wheels?
what size front brakes do you have and disc width?
do you have coilovers on?
thanks a lot mate
jamie956
Sep 1, 2015 10:50 AM
cossiecrew
17
Apr 1, 2008 10:40 PM
JohnnyB
Jul 21, 2004 10:24 AM
Ima-Racing500
70
Jul 5, 2004 08:03 AM
11
Mar 15, 2004 07:20 PM
