which lowering springs?
Old Jul 8, 2005 | 08:53 PM
Denial's Avatar
Denial
Default which lowering springs?
my 2wd saph has gmax springs and konis, but it doesnt sit right at all, i think the springs are -20mm, and it seems to high at the back. im thinking -25 would be better or do people tend to go for lower to get it sit nice and moody without being too much of an arse to drive?
Old Jul 8, 2005 | 09:56 PM
cossieguy's Avatar
cossieguy
I've got a set of Avo coilovers on my 3 door and can change the ride height to get it just right can also adjust the ride hard or soft. No more cocking about with spings.
Highly recommended
Old Jul 9, 2005 | 07:26 PM
swerv's Avatar
swerv
if you want some cheap springs that work well with the konis and will make it sit nice get some chassis dynamic springs -25mm , the rear is always meant to sit higher than the front so dont worry there.
as for colivers , once you get the car corner weighted your not really meant to touch them so i wouldnt say they are adjustable for any height you want, but yes if you have the money a worth while thing to do
p.s dont lower your sapph too much as you will find it a pig to drive
Old Jul 10, 2005 | 01:11 AM
rapidcossie's Avatar
rapidcossie
will swap you springs as mine are -25 and i think it sits too low!
they are h+r springs
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
richierich1986
Sep 18, 2015 03:29 PM
Adam Graham
Sep 6, 2015 06:04 AM
