bleeding brakes
Old Jul 6, 2005 | 10:16 PM
moonstone mike's Avatar
moonstone mike
Default bleeding brakes
I want to change the brake fluid on my 3 door ?
do i undo the pair of bleed nipples on one caliper on the front or do one nipple at a time ????????
plus is there any tips on how to change the fluid an easy way???????
Old Jul 7, 2005 | 10:50 AM
moonstone mike
Old Jul 7, 2005 | 04:50 PM
CraigW's Avatar
CraigW
when you bleed brakes, always go in this order, rear passenger side, the rear driver side, then front driver then front passenger, thats the order thay done mine in the garage when i watched them, they put it up on the lifter and pumped the pedal 3 times till it hardend up with air in, then kept it pressed down and then opens the nipple till the brake fluid spat out, do that on all brakes with the pump pump press motion.
hope that helps
Old Jul 9, 2005 | 08:12 AM
alan rainbow's Avatar
alan rainbow
hope that helps
NOT ON A COSWORTH YOU DONT
Old Jul 9, 2005 | 08:17 AM
alan rainbow
to bleed the rears turn the ignition on get someone to hold the brake peddle down about half way then open the n/s nipple and let fluid come out untill there is no air in it repeat on o/s turn ignition of the fronts are done the normal way as above
Old Jul 9, 2005 | 08:43 AM
alan rainbow
Old Jul 10, 2005 | 03:11 PM
moonstone mike
All done now!!!!
I removed the calipers to replace the seals and found that the drivers side only had one piston working and 3 on the passenger caliper sorted now and the brakes are the best they have been in the 10 years i have owned the car
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
