removing and replacing a water hose....
I have a series 2 erst and need to take off the water hose that runs from the thermostat housing to the rad, I will be replacing it with a silicone hose.
Will I be ok just doing a straight swap because water is going to come out and Im pretty sure that your not supposed to have any air in your cooling system which there will be when I put the new hose on
any ideas ?
Duncan
Duncan
Adam Graham
Sep 6, 2015 06:04 AM
