Pioneer AVH-6500 Touch Screen Flip DVD player
Model AVH-6500 i think, will get pictures tonight,
DVD AV Headunit is a must. Tailored to Pioneer’s new DVD Cyber Navi software, this component is actually a complete control centre with a built-in AV Master, digital AM/FM tuner and DVD player. The motorised, high-quality touch panel display lets you manage the entire system from audio and video settings to navigation commands with a simple tap on the screen. The easy-to understand Graphical User Interface guides you through the most advanced settings step by step.
The AVH-P6500DVD is compatible with the latest digitally encoded discs: DVD-Video, DVD-R/RW, Video Cd, CD-R/RW and MP3. Connect the DEQ-P7000 to your AVH-P6500DVD and transform your car into a multi-channel surround “cinema on wheels”! The handy Dual Zone function splits your entertainment space in two: you can listen to music up front while your rear seat passengers enjoy a different AV source, like a DVD film. Solid state sound is guaranteed with Pioneer’s high-quality MOSFET 50 amplifier and you can hook up external amps on the 3 Hi-Volt pre-outs or add a DAB tuner, TV tuner or multi-CD player to complete your in-car system. For extra convenience: the 10-character sub-display shows the audio-visual status when the touch panel display is closed. Key features AVH-P6500DVD
Fully Motorised Touch Panel Display, Dual Button illumination (green/red), MP3 CD Playback, DVD-Video, DVD-R/RW compatible, Dual zone operation with front Video and rear AV output, Back-up camera input, D4Q Digital AM/FM tuner, 3-channel Hi-Volt (4V) Pre-Outs (F+R+SW), General AVH-P6500DVD, Amplifier MOSFET 50W x 4 Equaliser EEQ+ Equaliser with HPF, LPF & SFEQ, Built-in AM/FM RDS Tuner D4Q (ARC 5), DVD Capabilities DVD-Video/Video CD/MP3 CD player, Built-in Linear PCM/DTS/Dolby Digital decoder , DVD-Video/Video CD Playback with Direct Search Chapter/Track, Next/Previous Chapter/Track, Fast forward/reverse, Pause, Track/Chapter Repeat, Condition Memory (30 discs), Play back Control (Video CD only), Direct Search Title/Group,
Time Direct Search, Scan, Digital Direct, CD Capabilities CD Playback with Track Scan/Pause/Repeat, Random Play, CD Text, List Search, 96KHz/24-bit DAC, 24-bit D/A Converter, Fast forward/reverse, Track Search/Scan/Repeat , Track/Manual search, Last position memory (for CD function only), Source Control MCD, SCD, TV DVD, DAB Tuner, Control via front panel buttons or Remote, Voice Guidance When connected to Pioneer Navigation System, Display type Wide Screen TFT active matrix LCD Color Display, Touch Panel Operation Yes, Display size 6,5 Inch Screen Coating High quality anti-Glare, Low-Reflection coating, Installation possibilities In-Dash , Fully motorised display with auto dimmer with free adjustable viewing angle (50 - 110°)
Front panel Removable with safety warning beep, Selectable wide screen modes Just / Full / Cinema / Zoom / Normal Input for rear camera Yes, Rear camera switching Yes, Dual Button illumination Yes (green/red), Remote Control Standard, D/A Convertor 24-bit , DVD - R/RW and CD - R/RW Playback Yes, Built-in MPEG 2/1 decoder Yes, DVD video player Yes, Region number 2, Connections AVH-P6500DVD, AV Output 3 Hi-Volt (4V) Pre-outs (F+R+SW), AV inputs 1 RCA, AV Bus Input Yes, RGB input for AV Master or Navigation System yes, IP Bus input/output Yes, DVD video output Yes
INFO ^^^^ took from Pioneer website LOL
£700 Posted!!
£700 Posted!!
how much will u take for yours
thanks
*EDITED BY WEBTEM*
Please do not post links to the item for sale at a cheaper price elsewhere on the web, this is a private add from the topic starter.
thanks
*EDITED BY WEBTEM*
thanks
*EDITED BY WEBTEM*
thanks
*EDITED BY WEBTEM*
LLW, i put £700 posted, if you want to make me a sensible offer (worthy of a reply) ill consider it.
HI, It may of been mentioned above, but I'm not too up on ICE, does it have SAT NAV with it or do I need to buy discs etc? I've been looking at the new Pioneer X1 thing and this looks simaler, although £400 cheaper!
Andy
Andy
Hi Andy, the XA1C or somat like that is more expensive cos it does have sat nav buddy. This is the model before that one, it can be used as sat nav, but you have to buy an add on at a greater cost that adds on more than the cost of XA1C(?)
Other than the sat nav, tis the same i belive!!
rsguy
44
Sep 29, 2015 03:29 PM
NC53
Sep 13, 2015 03:05 PM
