Garage Build............Pics on last page
what you reckon so far?
it's gonna be 8 metres long, and just over 5metres wide
http://bbs.rsownersclub.co.uk/showthread.php?t=74447
good size that is m8 friend of mine's just had one built @ 5x7meters top workspace
are you havin the floor 'powerfloated ' highly recommend it well worth the extra expense so much easier for moving engine cranes /cars on jacks too
Originally Posted by Spiky
i'm the walls white, and the floor will have proper garage floor paint
wish i had done mine a bit bigger,
mine is only 5.5m by 10 m
should have gone for 7m by 12m
with two cars side by side its a bit tight, and the lengh will fit two car end to end, but again there aint much room for the spares and tools,
one day when i can be assed i may exstend, but then if do that it will have to go to 15m or so, not practical to make it wider now as it will be to much work,
lol at your footing depth, when i did mine it had to be 750mm min
just like the houses ect
are you bulding it yourself spikey?
what are the planning regs and that, do you have to be a qualified builder? is your a single skin or double?
wana build me own sometime as the flat pack one i've got leaks
