anyone involved in automotive Air Conditioning?
Old Jun 24, 2005 | 05:35 PM
richm's Avatar
richm
Default anyone involved in automotive Air Conditioning?
Does the receiver/dryer have a finite life? ie it can only absorb a certain amount of moisture? (filled with silica gell as far as i can establish..)
Can it be 'rejuvenated' by baking for example, to drive off accumulated moisture?
I'm thinking if the system has been empty of gas for a while, or the dryer has been off the car for a while, then it may have to be replaced?
Any help or info appreciated!
Rich
Old Jun 24, 2005 | 05:44 PM
whitneyd's Avatar
whitneyd
If you give me a day I can find out for you.
Old Jun 24, 2005 | 06:11 PM
alan rainbow's Avatar
alan rainbow
dryer can be replaced is it one with a flared conection ie a nut each side of the dryer or is it sweated in or are you talking about the recevier
Old Jun 24, 2005 | 06:22 PM
richm's Avatar
richm
alan - yeah it is replaceable, fits between o-ring union blocks off the side of the condenser - I'm questioning what determines if/when it needs replacing??
Old Jun 24, 2005 | 07:14 PM
DazC's Avatar
DazC
If you have broke into the system and it is a few years old or there has been no gas in the system for a while, replace it.....
Old Jun 24, 2005 | 08:15 PM
jaypen's Avatar
jaypen
You may have a leak in system or pipework?(all systems loose a few grams over a long period anyway)
the machine at work can re-charge you system,find any leaks,vac system(remove moisture from pipework) & also add pag grade oil to you system all in on cycle!!!
also a do a U.V test (dye added into system,special dectector glasses & sensor probe to locate where if any you leak/s are.
i would sugest you get system checked 1st before you purchase a new condiensor rad?
i could have this checked out for you when you are down my way?
got all silicone 'O' rings if you need any
all worth considering mate
Old Jun 24, 2005 | 08:19 PM
richm's Avatar
richm
James, already know where the leak is in the UV light, there's a big glowing green patch on the core behind the fan
Old Jun 24, 2005 | 08:38 PM
jaypen's Avatar
jaypen
dohhhhh
best be ordering up a new rad then
Old Jun 24, 2005 | 08:45 PM
markk's Avatar
markk
if the system has been open for any period of time i.e no gas then the dryer should be replaced. i have done them and not , and some i have because the system would loose its effectiveness over a short term
Old Jun 24, 2005 | 08:47 PM
richm's Avatar
richm
ok cheers guys. new drier then - one's had no gas in for a while and the other's been sat on a shelf attached to the condenser..
Old Jun 24, 2005 | 09:45 PM
900ss's Avatar
900ss
RWD Racer
Originally Posted by richm
.. the other's been sat on a shelf attached to the condenser..
In a bloody hot warehouse I might add
Any moisture would have long dissipated !!
Ok, I made that last bit up
Old Jun 24, 2005 | 09:49 PM
richm's Avatar
richm
lol @ Wyn
i could hear you sweating on the phone mate!! lol
Old Jun 24, 2005 | 09:59 PM
900ss's Avatar
900ss
RWD Racer
A moment of sheer panic that's all
I dropped my wallet
Old Jun 25, 2005 | 08:51 AM
alan rainbow
rich replace it as a caution / it may not need replaceing but what happens is after a period of time if the dryer as absorbed alot of moisture they brake up and tend to block the system
Old Jun 25, 2005 | 08:57 AM
richm's Avatar
richm
Old Jun 25, 2005 | 12:01 PM
whitneyd's Avatar
whitneyd
Looks like your question has been answered.
Old Jun 25, 2005 | 12:03 PM
richm's Avatar
richm
thanks for the help guys!!
Johnny Knoxville
Sep 30, 2015 07:21 AM
Kam B
Sep 24, 2015 10:40 AM
Vacuman
Sep 22, 2015 12:09 PM
3doorcozmess
Sep 20, 2015 06:15 PM
