escort cosworth fuel filter
Old Jun 24, 2005 | 05:28 PM
tregmatt's Avatar
tregmatt
Default escort cosworth fuel filter
hi do anyone know were the fuel filter is on a escort cosworth and is it hard 2 change? many thanks
Old Jun 24, 2005 | 05:41 PM
Azrael's Avatar
Azrael
It's on right side beside fuel tank. NOt VERY hard to change but I think you must be care full as parts connnecting to it are unavalible.
Old Jun 24, 2005 | 05:43 PM
panty girl's Avatar
panty girl
get on your back and slide under the car were the fuel tank is it may be along beside the tank just follow the fuel pipe out of the tank, the fittings are just push on and the filter is held on with a clamp which is fastened with a screw or allan key thingy
Old Jun 24, 2005 | 07:33 PM
THE RADMAN's Avatar
THE RADMAN
the fittings are banjo bolts! make sure you have new washers for them and they will be corroded as well
Old Jun 25, 2005 | 12:00 PM
tregmatt's Avatar
tregmatt
i just look under the car is it loacted just up abouve the back drive shaft oin the driver side? thanks
Old Jun 25, 2005 | 12:03 PM
tregmatt's Avatar
tregmatt
forgot 2 say its a N 1995 small turbo converted 2 a big turbo thanks again
Old Jun 25, 2005 | 01:24 PM
THE RADMAN's Avatar
THE RADMAN
yep thats the one
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Escortdriver1
Jul 31, 2015 02:36 PM
Old ford
Jul 31, 2015 06:50 AM
