escort cosworth fuel filter
Jun 24, 2005 | 05:26 PM
hi do anyone know were the fuel filter is on a escort cosworth and is it hard 2 change? many thanks
Jun 24, 2005 | 05:28 PM
Its at the back of car drivers side, and its easy to change.
Dave
Jun 24, 2005 | 05:57 PM
Small turbo is in the tank and it can be a bit**
Jun 25, 2005 | 12:03 PM
the car was a smell turbo but has been coverted a big turbo. i have seen a big gray can just above the rear drives side drive shaft? many thanks
Jun 25, 2005 | 12:06 PM
if its proper big turbo, then it will be under the boot floor on the drivers side.
Jun 25, 2005 | 12:08 PM
its a small turbo converted 2 a big turbo N 1995.
Jun 25, 2005 | 12:43 PM
Fuel filters are identical on both
Jun 25, 2005 | 12:44 PM
Quote:
This is what you are looking for.
Jun 25, 2005 | 12:47 PM
Jun 25, 2005 | 12:50 PM
Quote:
Originally Posted by whitneyd
In the tank.
WHAT?
Jun 25, 2005 | 12:52 PM
It's a small turbo converted to big turbo. If he only see's one can it's in the tank the other is the filter.
Jun 25, 2005 | 12:57 PM
What is in the tank!?!?!?
Big and small turbos have exact same fuel system. On mine it's a big can on the right side of the fuel tank behind the rear right driveshaft. Quite expensive too ffor a fuel filter.
I don't understand what you are talking about that is to be in the tank.
Jun 25, 2005 | 12:59 PM
I just read this again and seen that he was talking about the filter and not the pump. I must be inhaling to many fumes. Sorry about that
Jun 25, 2005 | 01:00 PM
Jun 25, 2005 | 01:23 PM
Jun 25, 2005 | 11:24 PM
Fuel pump is high up above the rear diff.
Should be easy ish to change.
Two banjos either side of the filter and a bracket to loosen off.
Dave.
Jun 26, 2005 | 07:51 AM
it is as yioou suggested above driveshaft, it is straight forward, dont drop the little copper wahsers (they ideally need replacing) and keep your fingers crossed it was changed recenty so wont be seized
Jun 26, 2005 | 09:18 AM
Peeps cant read. we are talking feul filter Not pump.
Dave
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Escortdriver1
Jul 31, 2015 02:36 PM
Old ford
Jul 31, 2015 06:50 AM
