Difference in 3 door shells that no one mentioned, tunnel!
Old Jun 24, 2005 | 01:16 AM
Default Difference in 3 door shells that no one mentioned, tunnel!
The 3 door 1.6 GL tunnel (although still ample for the gearbox) has a narrower back end to it than the RS500 shell and the rear mounting brackets are in a different place, just thought it would mention it as no one did that i recall when i said i was using a GL donor shell and was asking for differences.
Is it just the 500 shell that varies like this, or do normal cossies ones also feature this extra room at the back?
Whats the purpose of the extra space, its FAR wider than the box, is it to allow the potential for fitment of some other transmission as well?
Old Jun 24, 2005 | 09:42 AM
bump
Old Jun 24, 2005 | 10:12 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
standard 3 door shell is the same as an RS500 shell.
Old Jun 24, 2005 | 11:07 AM
Jim Galbally's Avatar
Jim Galbally
standard 3door as in 1.6GL or as in standard cosworth?
Old Jun 24, 2005 | 11:39 AM
Doh's Avatar
Doh
on the early 3 door shells (pre late 84) the rear crossmember has 6 fixed captive nuts where as the later shells have sliding bolts
didn't realise there was a width difference though, except on the 4x4 shells (which obviously weren't 3 door)
Old Jun 24, 2005 | 11:49 AM
Stu @ M Developments's Avatar
PassionFords Creator
Maybe you have one that was destined for an autobox? I recall these were wider.
Old Jun 24, 2005 | 11:56 AM
Yes its the slider type arrangement on this, is that what all the 500 sheels were then? (i guess so as they are all after that date), presumabley thats why it changed was it?
Old Jun 24, 2005 | 12:02 PM
I dont think they did an Auto option on the 500 stu
Porkie's Avatar
Porkie
how do you know the old shell was from a genuine 500 chip? and are they actually different to normal cossie shells?
Old Jun 24, 2005 | 12:18 PM
I dont think they did an Auto option on the 500 Stu
No, i thought you were saying yours was wider? Ignore me, my heads up my arse at the moment.
Old Jun 24, 2005 | 12:20 PM
B19-TRB's Avatar
B19-TRB
Flexible lad aint ya!
Old Jun 24, 2005 | 01:15 PM
Porkie my reasons for this are:
The chassis number (only last oucple of bigits missing and the rest matches a 500 one)
The cut battery tray
The RS500 stickers glue could still be seen on the wings etc where they peeled them off when it was stolen
The RS500 dials
The genine RS500 front bumper etc with date still on it.
The only non 500 parts were a 200 block engine (which is obviously not original one for that shell anyway) and the rear spoiler which is a normal 3 door one but isnt the original one from the car anyway as the boot has been changed (you can tell from the wiring to the wiper etc), so if anyhing thats more evidence it wasnt a normal 3 door shell too.
Obviously you can never be 100% sure with any rs500 unless you buy it new from ford, but it does seem highly unlikely it wasnt one, every single thing anyone has been able to say about a rs500 seems to tie up with it, even the end caps on the intercooler where the 500 drivers side one points in slightly etc.
Old Jun 24, 2005 | 01:27 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
RS500 dials? Same as 3dr Cossie ones mate.
Old Jun 24, 2005 | 01:28 PM
rsnissan's Avatar
rsnissan
thats what i always thought
Old Jun 24, 2005 | 01:30 PM
Dials are not same as normal 1.6GL or whatever, same goes for seats and door cars and door mirrors.
Thought only the 500 ones had the higher speedo on them though?
Either way though, its the chassis number thats my main "clue"
Old Jun 24, 2005 | 01:34 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
PMSL
As for RS500 dials, i thought they was all the same as the 3dr, whats different
I'd have said it being an Auto shell, as the transmission tunnels im sure was bigger, did you have the engine and transmission with the 1.6 shell chip ??
Old Jun 24, 2005 | 01:35 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
No mate, 3dr/RS500 ones differ from Saff Cossie ones as they have a boost gauge and Saffs dont, but barring that they exactly the same.
Old Jun 24, 2005 | 01:36 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Surely that should be the only clue chip, everything else can be transplanted. I know someone who's putting cossie running gear in a 1.6 GL shell, can't remember who though
Old Jun 24, 2005 | 01:39 PM
Ah fair enough, i thought the normal 3 door ones were like the saph ones but iwth a boost gauge, i stand corrected, im not really a ford bufty as you know so all these little details are of little interest to me.
Anyway, suffice to say the only bits that arent rs500 spec are the bits that have been visible changed, the boot spoiler which appeared to have been repainted (over spray on the black bit) and the engine which was NOT factory fit, partly cause it was 200 and partly cause it was wired by Stevie Wonder.
Old Jun 24, 2005 | 05:57 PM
martinrs500labatts's Avatar
martinrs500labatts
there is different mounting plates for the rear trailering arms
spot welded on after they where made so the touirng car rs500 could run different mounting position as per the rules for racing,
you will not find these small plates on the three door cosworths as it was done by tickford on all rs500 cars before they where delivered.
Old Jun 24, 2005 | 06:03 PM
Oranoco's Avatar
Oranoco
Was just about to maention the rear trailing arm pick ups to impressive everybody but wasn't quick enough.
Old Jun 24, 2005 | 10:42 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
so will my 2.0l zetec (turbo) and T5 fit my 1.6GL i just bought??
Old Jun 24, 2005 | 10:50 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Like you care Dan, knowing you you will blag a free RS500 off someone at this rate
(remember to get back to em and make sure its RS500 rather than normal 3dr bumper n spoiler too )
Old Jun 24, 2005 | 11:56 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
sorry martin but tickford never spot welded the plates. it was done before they arrived at tickford.
Old Jun 25, 2005 | 08:36 AM
pugo's Avatar
pugo
chip, i am going down to my cossie in a mo, i will take some pics of the tunnel and post em up so you can point out the differences
being a bit of an anorak.......i like to know all the diffrences!
Pugo
Old Jun 25, 2005 | 09:19 AM
pugo, dont worry about it mate, i will get a picture of the two different tunnels anyway, easier to point out differences with both pics not one!
Old Jun 25, 2005 | 09:20 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
gotta ring em back monday mate
Old Jun 25, 2005 | 09:27 AM
Dan, yeah it will fit, although you may have to source a differetn gearbox mount to the one that comes with it.
Old Jun 25, 2005 | 02:08 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well, brom is doing the engine mounts, so he can do that too lol
Old Jun 25, 2005 | 05:28 PM
boXXer's Avatar
boXXer
GASH!
i always thought the 3dr's were EXACTLY the same as the 500's apart from the engine, body kit, and the trailing arm brackets. dont think anything else was different as tickford just pulled normal 3dr's off the production line, removed all the standard bits and fitted 500 bits, including the welded plates.....
Old Jun 25, 2005 | 06:37 PM
STUCOS's Avatar
STUCOS
Chip was the plenum etc ok
cheeRS stu
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
YODI
Aug 30, 2015 01:12 PM
john_3.0s
Aug 16, 2015 06:40 PM
wheelwizardrefurbs
Aug 15, 2015 05:54 PM
