Breaking big spec 2wd Sapphire Cosworth - Updated 21/7
Engine & Transmission
Complete engine, exhaust manifold, inlet manifold with throttle, fuel rail with injectors, distributor, cap and leads, intercooler, radiator, map sensor, alternator, starter motor, standard water and boost hoses, standard header tank, standard airbox, engine loom, ecu, flywheel, clutch and gearbox all done 77k miles and in perfect working condition £1750
Samco Blue Silicon Boost, Water, Ancillary, Hoses £250
Mongoose 3.5" Stainless Steel Exhaust System £250 SOLD
Pace chargecooler kit £250
2wd rear diff and shafts £200 SOLD
Pace RS500 intercooler SOLD
Bailey Stainless Steel Header Tank £100
RS500 airbox lid £75 SOLD
2wd prop £50
Bosch 3 BAR MAP Sensor £50
Spec-R Cooling Fluid Swirl Pot £50
Power steering pump, reservoir and hoses £50
Ramair Cone Air Filter £50 SOLD
Forge dump valve £50 SOLD
Fuel pump £40 SOLD
Collins Alloy Piston Dump Valve £40 SOLD
Escort Cosworth cambelt cover £25
Collins Alloy -31 Turbo Actuator £25 SOLD
2wd T34 silicone blue boost hoses £20 SOLD
Amal valve bracket £10 SOLD
Pipercross Crankcase Breather Filter £10
Other
Racelogic Professional Adjustable Traction Control and Launch Control System £250 SOLD
SECS Digital ECU Monitor £250 SOLD
OMEX Sequential Shift Light £75
Saebelt 3 Point Harnesses (Driver and Passengers seats) £50 SOLD
Complete car loom with Clifford Concept 50 Cat 1 Alarm System £50
Nomad Analogue Boost Gauge £25 SOLD
Racetech Analogue Oil Pressure Gauge £25 SOLD
Chassis
AVO Sports Evolution Fully Adjustable Coilover Suspension – done 2k miles £350 SOLD
Koni 2wd suspension – done 5k miles £250
Powerflex Poly Bushes (all round) – done 2k miles £150
Standard 2wd suspension £50
Front Alloy Strut Brace £50
Rear Alloy Strut Brace £50 SOLD
2wd front hubs £50
Fuel Tank £50
2wd front anti roll bar £50
Rear arms £40
Fuel and brake lines £25
Ford jack and wheel brace £20
Front track control arms £20
Chrome strut tops £10 SOLD
Braking
Front : Hi-Spec "Monster Billet 4" Alloy 4 Piston Calipers with Hi-Spec 335mm x 32mm Grooved Vented Disks on Alloy Bells, EBC Greenstuff pads £650 SOLD
Rear : 4x4 Rear Calipers, EBC Turbo Groove Vented Disks, EBC Greenstuff pads £150 SOLD
2wd front calipers and discs £100
2wd rear calipers £50
ABS pump and reservoir £50
ABS ECU £50
Goodrich Stainless Steel Braided Brake Hoses - rear £20 SOLD
Wheels
2wd wheels x5 with good tyres £150
Interior
Complete leather interior- seats, doorcards etc with dark dash and carpet £500 SOLD
RS500 steering wheel – RS horn push - £75 SOLD
Ford 2008 Tape and 2028 CD units £50
Complete lock set £50
RS ECU cover – black £30 SOLD
Sapphire Cosworth clocks showing 77k miles £25
Boot carpet with foam section and side panels £25 SOLD
Standard stereo with speakers and amp £25 SOLD
2wd gearknob £25 SOLD
Electric window switches £20
2wd interior clock £10
Other switches £offers
Headlining and other trim plastics £offers SOLD
Door lock solenoids £offers
Electric window motors £offers
Exterior
Moonstone blue bootlid with spoiler £100
Heated front windscreen £100
Moonstone blue 2wd bonnet £75
Moonstone blue nearside rear door £50
Moonstone blue rear bumper £50
All glass including sunroof £50
Moonstone blue Sideskirts £50
Rear window side trims with Sapphire Cosworth badges £20 SOLD
Moonstone blue front toe eye cover £20
Sapphire door mouldings £20
Nearside rear smoked light and number plate surround £15
Clear front indicators £15
Moonstone blue nearside 4x4 bonnet vent £10
Moonstone blue nearside electric mirror £10
Sierra RS metal boot badge £15
Cosworth boot badge £10
Car is still complete so engine can be heard running etc.
Open to offers on all parts.
2wd prop £50
Fuel pump £40 SOLD
Other
Chassis
2wd front hubs £50
Fuel Tank £50
Rear arms £40
Braking
ABS ECU £50
Wheels
Interior
Exterior
Originally Posted by SPADGE
I'll take the turbo please!
Let me know when i can collect it
Cheers Spadge...
Cheers Spadge...
Originally Posted by CraigN
i will take the ecu cover
please pm me payment details
Cheers Spadge...
Cheers Spadge...
Originally Posted by sapphireman1
i'm after a raven center console to match the leather interior do you have one.
cheers
cheers
Originally Posted by righthooker
i need a dif ,but why are they allways miles away,
wouldnt be going up to croft by any chance ??
