Need a actuator Arm before Saturday (wheres the best place)
I need the arm bit that threds on to the actuator which has the hole in it, (the bit that connects the actuator itself to the housing).
Mine has give up the goat,
who would supply these
Cheers.
Dont really want a complete actuator
Cheers.
Right Jano, now i know.
Its about 2 inches (50mm), not a major problem as we adapted the acuator arm and inceasd the thread on it using a tap set
Originally Posted by Jasesapphy
Seems a little John Wayne.
Like it though
Do you have spur marks on your carpet at home
Like it though
1. how do i fix it
2. will it work
if the answer is yes then i dont look for anything more complicated than a solution to the problem, you carry on your search and wait for days for your part hoping its the correct one, i would have the car back on the road in 20 minutes for Ł3
cowboy???? nah, just sensible mate
it works and lasts as good as anything else so why try to make it more dificult Thread
