why does my fan fuse keep burning out???
Jun 21, 2005 | 08:20 PM
Jun 21, 2005 | 08:21 PM
Is it the correct amp fuse? Shorting out?
Jun 21, 2005 | 08:22 PM
Fan motor going knackered mate.......they start to tighten up and blow fuses...just put a new one on my sapphy.....
Jun 21, 2005 | 08:35 PM
Too much current being drawn through it if it is melting. Probably between 30 and 45/50 amps to melt a 30 amp fuse....
Jun 21, 2005 | 09:15 PM
no its deffo fan motor my mate had the same problem and his 3 door set on fire
Jun 21, 2005 | 09:32 PM
better get a new fan motor then ...is this the same as on other fords or is it cossy special ?
Jun 21, 2005 | 10:09 PM
Common cossie problem mate, i put a whole new loom in mine...sorted
Cable fords use for the fans is shit out of the factory so you can imagine what it's gonna be like after 14 years!!!!!
Jun 21, 2005 | 10:17 PM
VERY common problem mate. Just replace all the wiring for the fans and it will be fine. I have done mine
Here is a VERY good Auto-CAD drawing i did for you
Jun 21, 2005 | 10:18 PM
its the initial start up drawing too much current, rewire them
Jun 22, 2005 | 11:26 AM
Not just Cossies that do this - Fiesta RS Turbo's do it alot as well!
Jun 22, 2005 | 11:29 AM
Jun 22, 2005 | 11:44 AM
I've rewired mine all toghether, seperate fan relay and fuse now. Its a common problem and a right pain. Best to rewire it.
Jun 22, 2005 | 11:53 AM
£3,000 worth of Autocad and the drawing looks THAT shit? Damn!
Jun 22, 2005 | 12:21 PM
just cut the wire and put a inline fuse in it and it sorted mine out
Jun 22, 2005 | 12:24 PM
Jun 22, 2005 | 12:27 PM
Jun 22, 2005 | 12:36 PM
Quote:
Originally Posted by B19-TRB
glad it aint fookin black pmsl!
we were getting cooked in that fookin bean tin!
Jun 22, 2005 | 12:37 PM
Aye we got Air Con now baby!
Its all kool!
Jun 22, 2005 | 12:46 PM
glad to hear that mate
can we pick up some small girls so they can heat us up when needed pmsl!
we cant get it too cold now can we LOL
Jun 22, 2005 | 12:50 PM
Jun 22, 2005 | 12:59 PM
yeah i know what they look like from the inside almost like an MR2 fook al in the back PMSL!
Jun 22, 2005 | 03:23 PM
Jun 22, 2005 | 03:24 PM
have put in a 75 amp fuse now hope it will work till i get the wiring sorted
Jun 22, 2005 | 03:27 PM
btw what kind of relay do i need??
Jun 22, 2005 | 03:29 PM
I got the same thing, had a new loom so it can only be the fans I guess. Still on standard fuse at the moment, might look to upping that... hope nothing catches fire
Jun 22, 2005 | 03:31 PM
if the fooker caught on fire i'd be seriously fooked!
Jun 22, 2005 | 03:34 PM
My fusebox is melted to fook anyway, previous owner didn't bother replacing a broken fusebox cover, then steam-cleaned the engine
Jun 22, 2005 | 03:39 PM
well only the part that's melted is where the fan fuse should be it did work a few mins ago when i pushed it against the contacts .. but will make a wire directly to the fans tomoz so i can switch it on and sort the wiring
things like these are getting me in 2 minds about it but yesterday racing that corvette well didnt
Jun 22, 2005 | 08:28 PM
PMSL at Tiffs diagram getting ripped!!
Jun 23, 2005 | 03:30 PM
if i wanted to put a fuse in tiff's drawing where should it be?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Rsmat
89
Oct 12, 2015 07:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Flatlinedan
Sep 18, 2015 12:41 PM
