Saphire cosworth Sills
Old Jun 21, 2005 | 02:21 PM
steventoon's Avatar
steventoon
Default Saphire cosworth Sills
Hi
Can anyone tell me how easy it is to replace inner and outer sills on the Saphire Cosworth. I've a few holes in mine and dont know whether to replace them or cut out the bad metal and get a replacment patch welded in flush and the weld ground down to make a good job of it.
Steve
Old Jun 21, 2005 | 07:55 PM
Moose 130's Avatar
Moose 130
At the back in front of the axel?
Old Jun 21, 2005 | 09:33 PM
steventoon's Avatar
steventoon
the inspection report that has been done on the car says
under side left outrigger excessive corrosion inner sill
chasis member underside right corroded
floor section corrosion on the front undeside floor pan and underside right floor pan.
the inspector also mentioned that the outer sills may be corroded due to the age of the car but he couldnt see due to the skirts.
not sure if this helps or not !
steve
Old Jun 21, 2005 | 09:38 PM
Moose 130's Avatar
Moose 130
that's fairly vague.
If you're going to chop out large sections like this brace the car front to rear and side to side.
Can you get good pictures of the areas (not necesserily the corrosion)?
Old Jun 21, 2005 | 09:59 PM
steventoon's Avatar
steventoon
Cheers Moose,
I'll sort out some pictures ( may take a week or so ) and post them up.
Thanks again
Steve
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
