My car....(updated with more detailed spec)
INTERIOR:
Full leather Recaro interior:
Stack ST8130P* - Speedo / Rev counter / oil pressure / fuel pressure / water temperature (before radiator) / oil temperature / battery / fuel level / odometer / tripmeter / manual lap timer.
All idiot lights replaced with custom items.
Exhuast Gas Temperature gauge - Defi*
Water temperature gauge (after radiator) - Defi*
*Peak memory recall and alarm warning on all readouts, with record and play-back on APEXi and Defi items.
Boost pressure gauge - APEXi 2.5 bar*.
Electric sunroof.
12 position boost control - 1.0 to 2.2 bar.
Willans Harnesses.
Momo gear knob.
Pectel Monitor mounted in centre of dash.
WHEELS & TYRES:
Wheels: Compomotive MO cast alloy, 8" x 18", ET15mm offset.
Tyres:
Front: 245/35ZR18, currently Dunlop Super-sport Race
BRAKES:
Front: AP Racing 378mm (15") CP3700-1010/11G8 grooved and ventilated discs (fully floating) with gold anodised aluminium bells. AP Racing CP6235 6-pot differential bores, liquid-cooled, WRC callipers, and stainless-steel braided hoses. Ferodo DS3000 (CP6235D46) pads.
Rear: AP Racing 315mm (12.4") CP3580-64/5G8 grooved and ventilated discs wth gold anodised aluminium bells. AP Racing "Ex-works" Grp A, Ford Motorsport CP3620 4-pot callipers with titanium pistons and stainless-steel braided hoses. Ferodo DS3000 (CP3215D50) pads.
System: Hydraulic, dual-circuit with vacuum servo assistance and Teves ABS. Reyland hydraulic handbrake actuation.
ENGINE:
Type: Ford-Cosworth YBP
Capacity: 2180cc
Bore / Stroke: 92mm/82mm
Compression ratio: 7.54:1
Max. power: 477bhp @ 7010rpm @ 27 PSI**
Torque @ max. power: 358lb.ft
Max. torque: 408lb.ft @ 4520rpm @ 27 PSI**
Power @ max. torque: 351bhp
Specific output: 218bhp per litre.
Power / weight ratio: 335bhp/tonne.
Cylinders: Four, in-line. Accralite 92mm pistons.
Cylinder head: Works spec medium ported head (carried out by Nick Waples), with short duration cams.
Block: Cast iron (200 Series), WRC tri-metallic head gasket and long-studded.
Bottom end: Farndon 82mm crank, WRC high pressure oil pump.
Valve gear: Four valves per cylinder (35mm inlet / 31mm exhaust),
3-angle valves / seats operated by belt-driven twin overhead camshafts and inverted hydraulic bucket tappets operated by Isky valve springs. Big wing (5˝ litre) baffled sump and Bailey crankcase breather kit with braided hosing.
Fuel and ignition: Webber-Marrelli fuel injection with P8 ECU, Pectel Super 8 control board, Pectel monitor, water injection, Ford Motorsport leads, distributorless ignition system and ALS board. WRC siamese (side by side) 8-injector inlet manifold. AGP 071 plugs, eight 803 (dark green injectors) and 3 bar MAP sensor. Specially programmed
Ahmed Bayjoo ISS (Intercooler Spray System) chip live mapped on engine dyno.
Cooling: Pro-alloy Motorsport 50mm radiator, SPEC-R header tank, swirl pot and water-cooled power steering reservoir.
Induction: K&N panel filter inside modified standard air box T04E turbo (57 trim) with Maram 247 shaft 360° bearing etc, -31 actuator, Pro-alloy 65mm "super-wide" RS500 air-to-air intercooler and water injection (2 x 0.6mm jet). Boost controlled by Ford Motorsport air injectors.
Installation: Front, longitudinal
Exhaust: Mongoose 3" system with oval tail pipe.
Water injection
SUSPENSION:
Front: Independent by LEDA gas filled adjustable dampers with Eibach 325lb springs. Macpherson struts, set to 2.25° negative camber, 0" 20' toe in. Standard 29mm anti-roll bar with polyurethane bushes.
Rear: Independent, by semi-trailing arms, LEDA gas filled adjustable dampers with Eibach 175lb springs and standard 22mm anti-roll bar. Grp A 6° Zoo ream beam set to 2° negative camber and 0" 20'
toe. Polyurethane rear axle bushes.
Rear bumpsteer:
Bump
60mm - 0.030" toe in
50mm - 0.023" toe in
40mm - 0.015" toe in
30mm - 0.009" toe in
20mm - 0.005" toe in
10mm - 0.003" toe in
Droop
10mm - 0.001" toe out
20mm - 0.002" toe out
30mm - 0.003" toe out
TRANSMISSION:
Type: Front-engine, four-wheel-drive
Gearbox: MT75, five-speed with Swedish (Fixit) gear kit.
Alcon six-plate paddle clutch with Reyland hydraulic actuation.
Front diff:Quaife ATB in thickwall casing.
Rear diff: Quiafe ATB in standard casing.
Internal Ratios (FIXIT Gearkit): 1st 3.00:1; 2nd 1.99:1; 3rd 1.33:1; 4th 1:1; 5th 0.825:1; Reverse 2.75:1; Final drive 3.62:1 giving 24.84 mph/1000rpm in top gear with 225/40x18s. Maximimum speed in gears at 7500rpm (rev limited to 7800):
1st 52mph
2nd 78mph
3rd 116mph
4th 155mph
5th 187mph
STEERING:
Type: Power-assisted rack-&-pinion
Lock-to-lock: 2.4 turns
BODY / CHASSIS:
Type: Pressed-steel monocoque, based on conventional Sierra / Escort, in two-door style.
Chassis construction: In steel, as part of monocoque
Dimensions:
Length: 4211mm Width: 1727mm Height: 1425mm Wheelbase: 2551mm Front track: 1453mm Rear track: 1472mm
Actual Weight: 1425Kg* (on road)
On track weight: 1395kg* (tool kit, spare wheel and rear
MDF shelf removed).
*Measured with half tank of fuel, wet weight without driver (75kg).
**Power is on dyno with no ancilliaries, but dynoed with Mongoose exhaust for as close to true power as possible. Estimated to be approx 450-460bhp in car with power steering / alternator drain etc.
Torque should be around 430lb ft now, as in the car it has been mapped for a 2.2bar (32psi) mid-range spike (3500-5000rpm), tailing off to the original 1.8bar after 6000rpm.
At Bedford
At the Nurburgring
At Snetterton
At ND 2004
Thanks to the following people for helping make the car what it is:
Harvey Gibbs, for building an engine so reliable, that I have hardly seen anything of him for the last two years
.Ahmed Bayjoo for being the God of mapping
.Reyland for the hydraulic clutch, handbrake, rear brakes, paint and patience to put up with a fussy git
.Steve Scott for sourcing some of the hard to get bits at the right prices
.Zoo for the rear beam - does what it says on the tin
.Gary at APT for dropping everything as and when required for bits and pieces
.Bernie at CTS for building up the Swedish gearkit quick-smart last year.
Chris at Carnoisseuar for lending me his Quaife for 6 months while I sorted out my Fixit kit (I'll never forget that
).Tomas at TG Racing
.Jen for putting up with a hobby that consumes such a big part of my life
.My Mum, Dad, the good Lord, my agent etc etc
and not forgetting IMA Racing for all his advice (that I then duly ignored and did the correct way
Nice spec
You took my mate Alpina (white 3 door with stripes) out in yours at Bedford and he said it was just awesome, handling was immense,
Maybe if I'm at at the same track day as you sometime you could take me for a ride in it. Think I spotted you at the Classic ford show in it ? looked lovely in the flesh.
Great job Nik has done of the head too from the pic, how long did you wait for that
Jonny Bravo,
If you see me at any track day, all you have to do is ask (and that goes for anyone who wants to ride shotgun)
Yep, twas me at Classic Ford (love the old school cars
I didn't have to wait on this occasion, as the head was on the car when I bought it...
Nuts,
That is actually my next mod. I'm trying to find a reasonably priced second hand Recaro SPA, so keep your eyes pealed
Thanks everyone for the kind comments, as you know with me, Cossies are a labour of love. I could have had something "better", but I just prefer Cossies
.#Yep, twas me at Classic Ford (love the old school cars
).I didn't have to wait on this occasion, as the head was on the car when I bought it...
Nuts,
.Thanks everyone for the kind comments, as you know with me, Cossies are a labour of love. I could have had something "better", but I just prefer Cossies
Absolute monster of a car, perfectly balanced in every aspect.
A passenger lap of the Ring in this is possibly one of the most exciting thing's I have ever done.
Mike, DON'T EVER tell my bird that!
Awesome car, awesome driver.
Ha, you were lucky on the head then, his stuff is top notch, I'd like to get one for my engine but I think I should worry about getting the car done and not ripping the already built engine to pieces lol
i will most probably get one done at a later date though.
I'll be taking you up on that ride, I'd say I'll so the same for you but I doubt my car will give you much excitement, ur still welcome to a ride in it though if u wanted
jaw dropping
