piston rings on a moped?
Team HOTHOT!
alrite people wird one but me mates ped needs new piston rings ( im ment to be buying it
) are they hard to fit or is it simple as takin off the bolts off to get to the piston, taking off the old ring ( dont no how many there are and dose it have to go on a certain way? ) then compressing it / them and putting it back together?
hope some one can help
thanks
) are they hard to fit or is it simple as takin off the bolts off to get to the piston, taking off the old ring ( dont no how many there are and dose it have to go on a certain way? ) then compressing it / them and putting it back together? hope some one can help
thanks
Not a big job on most 2 strokes mate, but depends if the barell is scored or gone oval etc.
If it has then you need it rebored and a larger piston and new rings.
Ive got away with just rings before though.
Id want to knock at LEAST a couple of hundred quid off the asking price though if i were you, it isnt a 5 mins job for you to fix it (cue some smart arse with a 4 mins ring change record on a scrambler, lol)
Team HOTHOT!
got it down to £500 hes buying the rings , already got a 70cc kit on it and hasnt been riden with bad rings coz he got a car so should be just rings, dose ride fine just smokey
deathrider666
Sep 28, 2015 06:12 PM
