NA 1800 zvh Questions.....
Old Jun 20, 2005 | 11:12 PM
paconassa's Avatar
paconassa
Default NA 1800 zvh Questions.....
if anyone could help me, im starting this project on a 89' escort xr3i and my main question are:
-Compression ratio (maching the head, etc)
-Connection with gearbox (stock clutch or not)
-What blocks (mondeo, escort, focus and years of manuf. all pref without mods water pumps, sumps etc)
-other things you think of....
Old Jun 23, 2005 | 11:32 AM
big_wig_074's Avatar
big_wig_074
youd ideally want the escort 1800 mate as the sump and oil pick up are right for it,the head will then go on fine with a standard ford cvh gasket,gearbox fits fine as far as im aware,tha clutch is ok also,the flywheel bolt holes need to be slightly oversized though IIRC, water pump needs to be swapped with an adaptor plate(Mad For It do a conversion kit i think)
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
Del gsxr
Sep 19, 2015 05:53 PM
