RS 1800 parts to EscortGTi
hey all, along time ago i had to scrap my beloved rs1800 but i kept the engine, running gear, ecu and superchip etc..... as i always wanted to get another mk3 or mk2 fez and just slap in that engine......... anyway i'll cut to the chase i just got an r reg escort gti and was wondering what i could take off the rs1800 and put on the gti
am i wrong and guessing that the superchip will just plug in
or will it need a set up or is the chip useless
also ive got a fse power boost valve,,, will this work
any help guys would be excellent,
i dont think anything will just plug in no.
you can fit the cams but the throttle body wot fit directly so you need a 2.0l mondeo throttle body.
im sure the ecu wont work, if it was out of a very late m/n reg rs1800 it might work but i wouldnt be sure on it.
best to change the loom over with the ecu.
but the easiest option would be to fit a mk6 130bhp ecu out of some convertables
