Cossie Compression test
Old Jun 20, 2005 | 04:58 PM
pee vee's Avatar
pee vee
Default Cossie Compression test
what should the results be (approximatly) for a
Standard spec cossie engine??
i've just done one by the book sorta thing
(warm engine)
got these results
Cylinder 1 : 160 PSI
2: 156 PSI
3: 154 PSI
4: 155 PSI
just wondered what a standard engine would be expected to show?
Old Jun 20, 2005 | 05:28 PM
rapidcossie's Avatar
rapidcossie
thinks thats ok
Old Jun 20, 2005 | 05:33 PM
Dave Henshall's Avatar
Dave Henshall
130 psi is what the book says for new, has you head been skimmed?
well it actually say 8.5 bar at starter motor speed with a standard C/R of 8:1
before anyone jumps in
Old Jun 20, 2005 | 05:38 PM
pee vee's Avatar
pee vee
think it must of been mate.
its had a group A head gasket so i would say it was done then.(before i had the car)
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
