what is the boost level on a standard 4x4 saff cossie??
Old Nov 13, 2003 | 07:27 PM
RSCossieGaz's Avatar
RSCossieGaz
Default what is the boost level on a standard 4x4 saff cossie??
as topic states what should be the boost level?
Old Nov 13, 2003 | 07:34 PM
B11GNS's Avatar
B11GNS
0.7 bar
Old Nov 13, 2003 | 09:18 PM
hi gaz??
what you running mate???crank it up dude.....
you know you want to!!
Old Nov 13, 2003 | 09:34 PM
RSCossieGaz
believe me bob once its run in she will be.
at mo engines standard not chipped so what sort of boost should it run
Old Nov 13, 2003 | 10:02 PM
Hiya Gaz...it should be under 1bar .....cos when i had a saf and was stg 1 it was 1bar.....so 0.7 sounds correct for std...me thiinks....whats it running ?
Old Nov 13, 2003 | 10:04 PM
when i saw you at ace that night and took you up the road for a blast...i said that it was running a bit off!!!it had a prob with the chip...had a new one put in and flies m8....clutches and gearboxes here i come!!!
Old Nov 13, 2003 | 11:03 PM
RSCossieGaz
sweat bob look forward to another ride in it
missed ya at middx meet last monday you left just as i arrived saw go off,was abit deadd tho!
Old Nov 14, 2003 | 05:17 AM
3door's Avatar
3door
wnen and where is the middx meet..i know a 3 door that will come
FlashRS
Sep 14, 2015 12:36 PM
cossie330
Aug 22, 2015 12:00 PM
Anutternutter
Aug 21, 2015 06:07 PM
mrmann
Aug 20, 2015 11:24 PM
JasonPD
21
Aug 20, 2015 07:36 PM
