what would cause??
Old Jun 13, 2005 | 06:36 PM
escortrsmatt's Avatar
escortrsmatt
Default what would cause??
was cruising at about 30 in the 4x4, and then had no power at all!!the car was still running but pressing the throttle did nothing.car stalled when it eventually stopped.then when trying to restart would start then stop again straight away!!fuel pump was running ok.then after arranging a push home(just round the corner)decided to try it one last time and it started as if nothing was wrong!?!?
Old Jun 13, 2005 | 06:57 PM
escortrsmatt
any ideas??
Old Jun 13, 2005 | 07:17 PM
escortrsmatt
i thought maybe it could be the crank sensor??would this cause the ecu to stop opening the injectors?
Old Jun 13, 2005 | 07:34 PM
Chris Honeywell's Avatar
Chris Honeywell
map sensor?
Had similar on mine
Old Jun 13, 2005 | 07:47 PM
escortrsmatt
would that show up on a fault code reader??
