flywheels
Old Jun 13, 2005 | 04:42 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Default flywheels
is there any differance in thickness between 2wd 4wd flyweels ?
also when fitting a paddle clutch should the cover fit flush to the block?
thanks
Old Jun 13, 2005 | 05:57 PM
Porkie's Avatar
Porkie
Pretty sure the 2wd flywheel is lighter. They are definately different, but not sure about thickness sorry.
Old Jun 13, 2005 | 06:54 PM
Retro Al's Avatar
Retro Al
RWD IS KING
ok cheers
Old Jun 13, 2005 | 08:21 PM
Retro Al's Avatar
Retro Al
RWD IS KING
anybody else any ideas?
Old Jun 13, 2005 | 08:55 PM
the original's Avatar
the original
normally the rear of the flywheel (gearbox side) should be completely flat and the clutch cover should be flush to that, just apply the correct torque to the cover bolts, on 4wd the inertia ring is much wider but i don't think the flywheel is any thicker, they all vary as most have been skimmed at some point
Old Jun 13, 2005 | 08:59 PM
the original
p.s i would get a lightened flywheel on your mk1, you don't need it as heavy as on a big old sierra, i have lightened ones on escort and cortina, rev up faster
Old Jun 14, 2005 | 12:04 PM
Retro Al's Avatar
Retro Al
RWD IS KING
well since i took gearbox off there has been some surface rust on the flywheel,i have tryed to get it off but its marked the flywheel so maybe a good idea to get it skimmed a bit
Prickly_buzz
Dec 7, 2017 09:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
