from 803's to 403's
Old Jun 13, 2005 | 04:12 PM
wimwerf's Avatar
wimwerf
Default from 803's to 403's
Hi,
If im changing from 803's to 403's with a chip for 403's....and im leaving my boost pressure at 25psi does the bigger injectors give me any more bhp/torque...just wondering...
my spec is: t34(360).63, 803's, -31, 3barmap, full magnex, K&N cone&alu trumpet, group a coil, blue leads, late escos headgasket with ARP headbolts...boost peak 25psi and 23 continue...
regards....
The change in torque comes from more boost.
Old Jun 13, 2005 | 04:16 PM
Rhys's Avatar
Rhys
Why would you chenge your injectors but not up boost anymore etc?
Old Jun 13, 2005 | 04:22 PM
CossieEdd's Avatar
CossieEdd
Surely you will be overfuelling if you leave the map unchanged ?
Same injector opening time with a bigger injector - I guess you'll get bore wash if it runs at all.
wimwerf's Avatar
wimwerf
i was just wondering.....
Old Jun 13, 2005 | 04:31 PM
He said a different chip though, so the map wouldnt be unchanged.
Old Jun 13, 2005 | 04:46 PM
wimwerf's Avatar
wimwerf
what would be a normal boost pressure for these kind of injectors.....
and i mean normal...
Old Jun 13, 2005 | 04:51 PM
Peaking at 2 bar or more.
Old Jun 13, 2005 | 05:00 PM
jp's Avatar
jp
I think its no more than 27 psi for these injectors iw as running 25psi on mine have them available if you wish to buy no done many miles and you will need to get youcar live mapped and setup for these.
Old Jun 13, 2005 | 05:18 PM
Chris Honeywell's Avatar
Chris Honeywell
27psi is what i run with my T4 and 403s
not sure what boost u can run with a T34
Old Jun 13, 2005 | 05:19 PM
CraigN's Avatar
CraigN
i wouldnt use an of the shelf chip with greys, you need to get your car set up with them
i was running 25psi on greys with a t34 on a collins chip was a bag of wank
had my car setup by karl peaks at 31psi and holds 26-28 depending on abient temps
and drives sooo much better
CraigN's Avatar
CraigN
27 psi on a t4 is flowing a lot more air than a t34 tho
Old Jun 13, 2005 | 06:48 PM
JonnyBravo's Avatar
JonnyBravo
A mate of mine from PF has 403's and a T34, he is holding 2bar and peaking a bit over that, its making just over 380bhp but broke the rollers on its full boost run, apparently it did run over 2 bar before he owned it but its plenty how it is now
seems a good setup for a t34, drives nicely
Old Jun 14, 2005 | 12:00 AM
MarK4's Avatar
MarK4
What cc are green / grey injectors?
SmudgerByName
52
Jul 28, 2016 06:14 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
Tim Wharton
Aug 30, 2015 05:46 PM
