RS Turbo disc conversions
Front brackets (to suit 2wd Cosworth discs) £47 delivered
Braided hoses - £30 delivered
Front discs - £POA
Can supply as a complete front kit
Rear brackets (to suit 2wd Cosworth discs) £47 delivered
Special extended braided hoses to suit - £30 delivered
Rear discs - £POA
Handbrake cable - £40 delivered
Can supply as a complete rear kit including brand new calipers.
Mail me on mike@rjpipe.demon.co.uk for details.
Front discs - £POA
Rear discs - £POA
Gus,
Yes, the brackets are designed for the standard 2wd rear disc, which I believe from memory is 273mm.
It can also accomodate the 4x4 disc which is the same size, but vented. This would obviously require the 4x4 calipers, which use a wider carrier.
Any caliper from the Sierra / Granada range with solid discs can be sourced from the scrapyard to use for this.
It is recommended that you also use a bias valve or get the load compensator adjusted to suit (SCC do this).
Best regards
Best regards
Matt Baxter
Sep 16, 2015 08:30 PM
atm
Sep 1, 2015 04:56 PM
