Cold air
Old Jun 11, 2005 | 09:12 PM
motherhupit's Avatar
motherhupit
Default Cold air
Does any one know a easy way to remove or redirect the coollant pipe witch goes from the automatic choke to the intake manifold and then throught the head, can i just disconnect this and connect on to another pipe. or is this the main cooling pipe leading into the cylinder head, since i want to stop the manifold from running hot to try and get as cold as possible air running to the engine . i have a 1989 mk3 fiesta 1.6 s cvh its off the hemipherical head type, its the same engine as the xr2 but its unleaded and has a different carb, thanks for your help.
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
