its not idleing right..!?
weird one
Car starts fine.. no probs all the way to the limiter.. but on idle, it hunts.. revs drop and go up
Sounds like its missing slightly, but only at idle revs...
Changes leads and plugs but still the same
I think the rocker gasket leaked as was oil around that area... But now Ive tightned them, it no longer leaks.. Could this have an effect??
thanks
thanks
cheers Andy..
I checked all the boost hoses and stuff as I thoufght maybe if 1 had a tiny leak it would corse this.. might all tight..
Idle screw... OK
Where abouts is this please...
only had the car 6 years
Idle screw... OK
Chesty, it's under the throttle body - right hand side (or thereabouts, it's a few years since I've had an ERST) large-ish knurled screw with a spring (don't let this drop when you unscrew it!)
Best to clean it with petrol or similar as it will be coked up. Then when you screw it back in all the way, unscrew approx 2 full turns (remember we're taling YEARS ago since I had one!) but obviously check the idle speed / stability.
It adjusts the air mix at idle IIRC, not the actual idle speed screw.
EDIT: would have beaten Rick if I didn't type so much
thanks lads
Im nervous
so, if i adjust it, it wont actually make the revs go higher.. it will just adjust the co at idle.. Cant do no harm can it
I apologise, but i am thick
and still dont know where you meen it is
here is a pic.. not mine but same engine
Im nervous
Chesty, it took me longer to do that pic than it would to find that screw
It's UNDER the main throttle housing block, not the inlet plenum.
Could be a sticky flap too I guess
@ Rudester.
@ Rudester.
I sprayed some of that carb cleaner yesterday.. only a little bit tho, and it seems to have semi sorted it...
I still dont know whwere that screw thing is
Chesty - possibly, I mean if you take the cap off, the engine should stall, so a leaky rocker cover could be an issue....... thought you'd sorted that?
LOL @ Katie, hope you now feel inferior Wes'side
As someone already said, it's more of a large screw with a knurled edge (thinger and thumb size, not a screwdriver jobbie)
the Westside is just keeping it real bongman...
Im going to go to a night class to learn
Ive bough the gasket... had it since last week.. but as you can imagine... Westcoast dont get no time
Originally Posted by Westy
hmmmmmmm, pic doesnt really help
cheers
will go check..
less of the gimp comment you butt slut
cheers
will go check.. less of the gimp comment you butt slut
