can some1 tell me what these compression results mean???????
Old Jun 11, 2005 | 02:51 PM
andre_k's Avatar
andre_k
Default can some1 tell me what these compression results mean???????
hey peeps, can anyone tell me if theese comp results are ok or not? my s2 is putting out a fair bit of blue smoke, on startup, idle and acceleration, none really on overrun that i can see, mainly startup and idle, comes and goes in intensity...
cyl1 2 3 4
Dry 170psi 168 170 175
Wet 185 psi 178 180 188
so an increase of about 10-15 psi during wet test... does this indicate piston rings worn enough for blue smoke? engines done 90k
cheeRS
Dre
Old Jun 11, 2005 | 02:55 PM
IANS2RST's Avatar
IANS2RST
all seam ok, more than likely your turbo thats onits it way
Old Jun 11, 2005 | 04:55 PM
AndyRST's Avatar
AndyRST
They are all good high figures there.
Have you taken the boost hose off and checked for play in the turbo shaft?
Could be valve stem seals, or worn piston rings or worn turbo seals.
Old Jun 11, 2005 | 04:59 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Sounds like Turbo Oil Seal to me.
Old Jun 11, 2005 | 06:13 PM
andre_k's Avatar
andre_k
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
