Fitting new intercooler
Old Jun 11, 2005 | 01:37 PM
James Raby's Avatar
James Raby
Default Fitting new intercooler
Do you HAVE to have ya car setup again?
Want to remove my GRS and fit the Pro Alloy one, but I don't wanna pay setting up charge ROFL
Old Jun 11, 2005 | 02:22 PM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
see how she drives!
ps keep your eye on the boost levels- you may need to back them off a little to return to where you were...
Old Jun 11, 2005 | 02:44 PM
James Raby's Avatar
James Raby
Wayne, I know I'd have to reduce boost level for sure
But ultimately, is it going to be ok to leave for a while
Does anyone on here know the real score with this?
Old Jun 11, 2005 | 02:49 PM
ballin's Avatar
ballin
if you set the boost back to how it was then will be fine
Old Jun 11, 2005 | 02:59 PM
James Raby's Avatar
James Raby
Reason I'mm asking
I'll be going from a twin pass intercooler to a single pass intercooler
The difference in air volume will be quite subsantial - i.e different tuning levels
Old Jun 11, 2005 | 03:04 PM
JamboRS's Avatar
JamboRS
focus rs 1672
it will be ok for daily driving but if it was mine wouldn't be hammerin it til its proper set-up
if you change any characteristics of the runnin of the car it needs set up afterwards to gain its full potential
remember grs has a pressure drop of upto 4psi so your turbo is workin harder than its actually showin on your boost gauge,addin a pro alloy raises boost pressure so i'd get it set up as soon as you can mate
Old Jun 11, 2005 | 03:06 PM
James Raby's Avatar
James Raby
My boost gauge shows exactly what the turbo is doing
But I do know what you mean
Old Jun 11, 2005 | 03:07 PM
Westy's Avatar
Westy
Old Jun 11, 2005 | 03:08 PM
James Raby's Avatar
James Raby
Paul =
Old Jun 11, 2005 | 03:11 PM
Westy's Avatar
Westy
Raby =
As jambo said really James.. I found I gained a few psi.. I took it easy on the road... Good it setup.. made sure enough fuel etc then gave it spuds
I drove about not set up, evryday for what must have been a good month or two.. So it will be fine, but done cain it too much. Ideally get it setup as soon as you can
Old Jun 11, 2005 | 03:12 PM
James Raby's Avatar
James Raby
Well, I'll leave it then, 'cos driving it like miss Daisy just ain't me I'm afriad
It's been given stick for the last 3 yrs now and still not blown, I'd ideally like it to stay that way
Not bad for an 8 yr old engine now is it LOL
Old Jun 11, 2005 | 03:16 PM
DanRSturbo's Avatar
DanRSturbo
Get it setup m8, be interesting to see what power it makes with the new cooler
Old Jun 11, 2005 | 03:19 PM
James Raby's Avatar
James Raby
I wouldn't know that, only RR round here is SCA
Or I could get it all done at JamSport, but all work on the car been carried out by Gary - would be rude to end it just before it gets pulled apart for better things innit!
Old Jun 11, 2005 | 03:29 PM
DanRSturbo's Avatar
DanRSturbo
Take it to Gary then
Old Jun 11, 2005 | 04:43 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Its not just about how much more/less boost it makes. If the Intercooler flows differently to the GRS you may find that it comes onto boost earlier or later. If it comes on earlier, your MF2 may not be set up to cope with that.
Just a thought.
Old Jun 11, 2005 | 04:47 PM
Matt's Avatar
Matt
what so you mean your not taking the boost gauge feed from the inlet manifold and are using the compressor housing instead then
PS get it set up properly
Old Jun 11, 2005 | 04:50 PM
The Sludge's Avatar
The Sludge
garibaldi
JR-good question that mate cos i have a pace ic and pace rad to fit and was wondering the same thing to be honest
Old Jun 11, 2005 | 04:53 PM
Christian and Beccy
#1 in Spelling Club
If you are going from a Standard Intercooler to one that is much different, then a Fuelling Check/Setup is DEFINATELY recommended.
I think James thinks that because he is going from one large Front Mounted Intercooler to another Large Front Mounted Intercooler that he can get away with it.
Old Jun 11, 2005 | 04:54 PM
Christian and Beccy
#1 in Spelling Club
Look at it this way......
If you are asking the question then thats because you realise that it may be a gamble, right?
You should only Gamble with as much as you can afford to lose.
Old Jun 11, 2005 | 05:12 PM
The Sludge's Avatar
The Sludge
garibaldi
cheers christian- my car is being resprayed at the minute and engine is down pj motorsport being rebuilt (lw comp) so really when this is fitted i aint got nowt to loose tbh when its set up aftrewards
just intrgiued me that a fully working car would or would not have to be set up again after fitting stuff like this.
question i think has now been answered
Old Jun 11, 2005 | 07:14 PM
james_birch's Avatar
james_birch
i had a boost drop (4psi) when i fitted my rad tec cooler....got it set up and a few weeks later my turbo shat its blade down the zorst! and everyone that looked at it said it seemed to have over ran itsself... ....never mind......maybe an air leak somewhere!...
Old Jun 11, 2005 | 07:20 PM
peteh's Avatar
peteh
How much for your old one james?
Old Jun 11, 2005 | 07:22 PM
Sexy-RS's Avatar
Sexy-RS
Get it set up agin I just had to get mine set up again after fitting the pro alloy and alex has got to take his back best to have everything 100%
James Raby's Avatar
James Raby
Christian, you once again have guessed incorrectly
Being a Saturday I didn't want to disturb APT and your work...
Purely asking a simple question and yes I meant what you did when you say about flowing differently
I just said it in a different way
As regards to my GRS and 2x10in kenlowe fans - PM me
SmudgerByName
52
Jul 28, 2016 06:14 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
