Compression ratios
Old Jun 9, 2005 | 08:19 AM
cng1's Avatar
cng1
Default Compression ratios
What compression ratios do people usually run on 360-420bhp engines? I'm just building up an egnine at present so have the opportunity to get the pistons machined down.
Up till now I've been running 7.7:1 on a 4x4. With the new build and the ported head I'm wondering if it's still worth retaining the lowered compression or whether people run standard compression on much higher power outputs than was the case back when my current engine was built up 5 or 6 years back. What do people think?
Old Jun 12, 2005 | 01:50 PM
The Gravedigger's Avatar
The Gravedigger
If you don't get any proper replies soon best bet is post this in Gen Discussion forum
Old Jun 14, 2005 | 02:52 AM
Smit's Avatar
Smit
The 60ft Launch King
The usual ratio is around 7.5:1/7.56:1 Anything over 440/450bhp IMO the 7.2:1 is the easy way!
Am i think right in your gonna be runng a a big blower? A .63 T34 runs out of puff at 400ish and a T4 is running out if steam on 403's at around 440bhp
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
