anyone ever snapped a driveshaft
anyone ever snapped a driveshaft ?
i thought i did my box in last sat lost nearly all drive so i went about removing the box to find the shaft had snapped where the teeth enter the diff fook knows how but it snapped so i thought should i remove the box or not (it was noisey)so i removed it for re build stripped it to find nothing wrong
so gonna put new bearings and seals in whilst its out .
Just thought id ask if anyones done or heard of the same with the shaft it is weird it drove like the clutch was slipping but its fine , then i presume the shaft was grabbing because it gripped a couple of times ?
so gonna put new bearings and seals in whilst its out .Just thought id ask if anyones done or heard of the same with the shaft it is weird it drove like the clutch was slipping but its fine , then i presume the shaft was grabbing because it gripped a couple of times ?
blimey
i busted a cv on way back from fitp and got all the way home (2hrs) on 1 shaft
went to replace it and the diff was locked so i have to change the box or not go round corners
now i have to change the box again cos the linkage inside it is stiffened up and hard to change
got a diesel box with lsd fitted ready to go in tho
Originally Posted by 1.9 xr2 on 40's
blimey
the 1 that locked?
it was fine n dandy, i dint think it was lsd as it dint really feel that positive thru the bends but when i took it our it was a propper lsd box, never felt like the clutch was gone tho, i just came out a mc'd's a bit lairy and hit a pot hole, thought the cv was hanging on for the journey but it was actually mullered and the drivers side shaft got us home (pulling left like a mofo tho on acceleration)
the box i just put in was a reconned xr2 box (had it to hand so bunged it in
that was slipping bad but the boost is down to 10 and sometimes maybe 15 now
but thats 20 psi thru a std cutch for ya
I've snapped a drive shaft in half before on my series 1.
Wasn't really giving it any round town, then this clunking noise appeared (bent/kinked driveshaft) didn't know at the time what it was, cause i couldn't see anything. Driving it home it finally snapped, still don't know why it did
