aeroquip fuel hose
Old Jun 8, 2005 | 03:34 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
Default aeroquip fuel hose
is there a easy way to get the braided pipe into the fitting without the metal fraying
Old Jun 8, 2005 | 03:38 PM
SLIM's Avatar
SLIM
get someone who does it for a living to make up the hoses for you with the fittings on them.
it shouldn't be too expensive.
Old Jun 8, 2005 | 03:40 PM
turbo terry's Avatar
turbo terry
fookin coont of a thing!! Makes a nice mess of your hands too!
Only ever done it once but found it was all in the cutting, put masking tape over where you are gonna cut(cut through the tape it so doesnt fray as much), twist it into the fitting
HTH
turbo terry
or as slim says!
Old Jun 8, 2005 | 03:46 PM
RichardPON's Avatar
RichardPON
The trick is to make sure you tape before you cut the hose, and then trim off any small bits that stick out at all.
Once you're done that, you should have no problem.
Old Jun 8, 2005 | 03:47 PM
NUTS RuS's Avatar
NUTS RuS
|Cut as above then wind it in backwards from the weave.
Old Jun 8, 2005 | 03:53 PM
Lloyd's Avatar
Lloyd
i tried that i will have another go tommorow,thanks
Old Jun 8, 2005 | 03:59 PM
DaveEscos's Avatar
DaveEscos
WRAP TIGHT IN MASKING TAPE
GRIP IN VICE... AND CUT WITH A DECENT HACKSAW
NO FRAYAGE
Old Jun 8, 2005 | 04:10 PM
Ginge !'s Avatar
Ginge !
just finding my feet
wrap in tape ( dont have to be masking, ive used insulation tape ) and stick in vice as dave said then cut with ya angle grinder, theres not a job that cant be done with a grinder
Old Jun 8, 2005 | 05:49 PM
THE RADMAN's Avatar
THE RADMAN
wrap in masking tape,use tin snips for a quick clean cut,then prick your fingers on the stuff lol
Old Jun 8, 2005 | 06:51 PM
rsnissan's Avatar
rsnissan
tin snips for frayed bits, a fine junior hacksaw and masking tape.
you will still get injured though somehow
Old Jun 8, 2005 | 10:39 PM
escort700bhp's Avatar
escort700bhp
THE BEST WAY IS A LARGE COLD CHISEL AND A HAMMER , SOUNDS CRUDE BUT ITS THE BEST WAY , TRY IT YOU WILL BE IMPRESSED
cheeRS
Fudgey
21
Sep 30, 2015 06:19 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
Russ Payne
Sep 25, 2015 08:29 PM
