dip stick is very lose? not good?
Old Jun 6, 2005 | 03:59 PM
zippyobrien's Avatar
zippyobrien
Default dip stick is very lose? not good?
hey to all you turbo fans.
on my 86 rs turbo the dipstick is very lose (you can move the tube to the left and right about 8 inches).
i assume that it shouldnt be like this but i cant see any way of tightening it?
any help would be greatfully recieved.
lee
Old Jun 6, 2005 | 04:05 PM
Manchester Mike's Avatar
Manchester Mike
Do u mean it rotates in the block?? Mine does this and shouldn't cause any problems.
hope this helps.
Old Jun 6, 2005 | 05:20 PM
rs_daz's Avatar
rs_daz
Mine also does this .. i put some ptfe tape around the bottom which helped keep tight...
Old Jun 6, 2005 | 08:05 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Just make sure it's fully pushed into the block, as if you check your oil, it may show it to be low, when infact it may be the correct level due to the fact the dipstick not going all the way to the bottom of the block.
Old Jun 6, 2005 | 09:03 PM
zippyobrien
thanks for all your advise lads,
it is much appreciated. will try all advise.
Old Jun 7, 2005 | 07:13 PM
James Raby's Avatar
James Raby
Mines the same, been told to loctite it into place
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
Sep 3, 2015 10:49 AM
turbowag
Sep 3, 2015 08:07 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
