Car hesitating
Old Jun 5, 2005 | 10:55 PM
Nice_aRSe's Avatar
Nice_aRSe
Default Car hesitating
Right this is a strange one.
Its only happened since once again fitting the Bailey Breather kit.
I can be cruising down a road and all of a sudden car jerks very slightly then drives like normal again.
Doesnt happen in any particular gear or any sort of revs.
Is totally random.
Any ideas?
Old Jun 5, 2005 | 11:38 PM
escort frenzy's Avatar
escort frenzy
Check you've put the hoses on right. The hose that goes to your air box leave it off then blank of the pipe from your airbox with a bit of pipe and a plug. Hope this works
Old Jun 6, 2005 | 06:50 AM
Nice_aRSe's Avatar
Nice_aRSe
At the moment i have a pipe from bottom of breather across to the airbox, you saying i should disconnect this?
Old Jun 6, 2005 | 10:07 AM
james_birch's Avatar
james_birch
ywah he is! .......just block it off and go for a drive!
Old Jun 6, 2005 | 10:09 AM
Nice_aRSe's Avatar
Nice_aRSe
Hmmmm fitting kit says your meant to have that pipe there otherwise where is breather going to vent vapour too
I disconnected the cold start valve this morning and it seemed better on the way to work
Old Jun 6, 2005 | 10:23 AM
james_birch
havent got a clue! but what if ya running a induction kit....or does it go to the metering head! there was a how to in last months performance ford on how to fit one! (not saying you done it wrong) or call bailey...they might know why
Old Jun 6, 2005 | 10:38 AM
james_birch
nice aRSe heres bailey's contact page
http://www.baileymotorsport.co.uk/ba...ort/frame.html
Old Jun 6, 2005 | 10:43 AM
james_birch
nice aRSe...just reading about the kit and it says
"The small amount of unwanted oil vapours thet are separated from the oil are vented under the car to atmosphere."
dunno if that means anything....
Old Jun 6, 2005 | 10:46 AM
Nice_aRSe's Avatar
Nice_aRSe
Ive rang bailey just mate cheers.
You do connect the bottom breather pipe back into the metering head. He said i may have an air leak where the grommet is going into the metering head so i will check this later
Old Jun 6, 2005 | 05:45 PM
Manchester Mike's Avatar
Manchester Mike
i have a bailey breather, i've blocked the pipe that goes into the metering head, the one that would have gone into the metering head from the pot now goes under the car into atmosphere but i think for polution laws your not really supposed to do this, thats maybe why mr bailey advissed against it. but either way it shouldn't cause any running problems so i'd check all pipes are secure and undamaged.
hope you get it sorted.
Old Jun 6, 2005 | 07:30 PM
Nice_aRSe's Avatar
Nice_aRSe
I disconnected the cold start valve and so far not had any hesitating like before
Old Jun 6, 2005 | 09:46 PM
james_birch
bring on winter!.......dont know why ya cold start valve would start playing up aftre ya fit a breather tho
Old Jun 6, 2005 | 10:23 PM
Nice_aRSe's Avatar
Nice_aRSe
Because the breather is making things flow easier and the intake plenum no longer receiving vacuum from the standard breathing system.
Or summat like that all i know is its fine now and thats all that matters
Car will still start in winter without it anyway, just need to pump the accelerator a bit first
Old Jun 7, 2005 | 08:38 AM
james_birch
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
