escort cab induction
How do u fit an induction kit 2 a mk4 xr3i cab? Iv just bort a shitty universal 1, just 2giv it sum more poke til i can afford my turbo transplant, n as soon as soon as i put it on the car cut out??!!
I fink its sumfin 2do wiv it bein an MFI engine n theres sum mad fuel regulator type fing on top of the airbox. Ne1 no how 2 get around this???
Unfortunately you cant put a universal one on cus you need the fuel flow meter. I will put up a picture for you in a mo. But you need everything on the engine as is!
There are two options when it comes to induction kits for MFI CVH's and they are the only two I know of. One is to put in a sport filter and then drill the box, which is a bit cheaper and easier to do.
The other is to buy a kit that gets rid of the box. Basicly its an airfilter in a cage that you bolt inplace of the original box and then put the meter on the top, but YOU NEED THE AIR FLOW METER OR IT WILL NOT WORK if you are running MFi.
There you go. The part makerd G is the air flow meter/fuel distributor. This is what regulates fuel flow to the injectors. you remove this your in trouble
Any induction kit you buy should bolt on under it.
Oh so that explains it!! Nice 1, looks like its drilled airbox time.
Duz ne1 reckon itl b worth convertin 2 EFI or just waitin 4cash flow 2 start up agen n gettin turbo lump??
Iv heard EFI is slower than MFI, is this true??
Iv just bin speakin to a guy that manufactures kits, i got his e mail from this site. He sed sum1 shud make a kit for it all 2 bolt in place of the airbox, duz ne1 no who makes such a fing or where i can find1??
Theres gotta b sum1 wiv an MFI lump thats got induction surely??
Yeah Amber Performance do a kit which is where I got one from you can give em a call on 015 8257 2500. its the dogs nuts I tell ya and it bolts right in place of the Airbox under the fuel meter.
Dr. Ickxs
Sep 15, 2015 10:15 PM
