chips
how easy are super chips to fit on a 2wd coworth ecu as i have not got a clue we're to start aand whats the diffrence between l6 and l8? do they both still work on a 2wd or is one for a 4wd, thanks for looking
l6=2wd
l8=4wd
chips not interchaangeable m8
ecu's are as far as i know but you need to change things to accept differnt ecu, such as throttle position sensor and wiring and stuff
fittin the chip is easy if you are carefull
l8=4wd
