Bailey breather kit fitting
Old Jun 4, 2005 | 02:00 PM
Nice_aRSe's Avatar
Nice_aRSe
Default Bailey breather kit fitting
FItted my second hand one today and couldn't see anywhere for the pipe from breather to plenum to go so just plumbed it up with a bit of wood.
Is it correct that you just block it off?
Old Jun 4, 2005 | 03:05 PM
James Raby's Avatar
James Raby
I 'think' you can get a blocker - just a bit of plastic - fits in same hole with same thread from Bailey
Or, alternatively get an ACT gauge
Old Jun 4, 2005 | 05:57 PM
1.9s1's Avatar
1.9s1
This is the part you need, it comes with the fitting kit. if you pm me an address i'l chuck it in an envelope and post it to ya
Mark
Old Jun 4, 2005 | 05:58 PM
James Raby's Avatar
James Raby
That's the kiddy!
Old Jun 4, 2005 | 08:56 PM
Micky's Avatar
Micky
Hi ,just see in youre engine picture that you have no cambelt cover fitted,I'd advise you to refit it as a stone could get jammed between the belt and pulley resulting in piston to valve contact,not a cheap fix!!!!Regards Micky
edited as my spelling was woefull!!
Old Jun 4, 2005 | 09:44 PM
ballin's Avatar
ballin
yeah thats fine block it however
Old Jun 5, 2005 | 09:40 AM
Nice_aRSe's Avatar
Nice_aRSe
Since fitting the baileys ive seen some mayonnaise on the underside of the oil filler cap
What could that be? I cant see it being my head gasket as the coolant is fine
Old Jun 5, 2005 | 09:43 AM
james_birch's Avatar
james_birch
someone missplaced the helmans?....
might be sumit from the breather itsself from the last owner perhaps?unless its new then havent a clue! could have been sumit jammed in your engine but now that it breathes better its a little looser.?
Stoo's Avatar
Stoo
What were the original pipe's like when you took them off?
If you havent lost any coolant and under the cap isnt all that bad i wouldnt worry too much.Short journeys can cause this effect under the oil cap
Old Jun 5, 2005 | 10:00 AM
Nice_aRSe's Avatar
Nice_aRSe
Original pipes had a bit of oil gunk in them - They were still original!!
I drove about 5 miles and had a look and was a thin film of mayo under there
Old Jun 5, 2005 | 10:31 AM
james_birch
when was ya last oil change?......if was very recent then dont worrie if was a while ago might pay to do one incase ya have inadvertantly (sp) contaminated anything.
James Raby's Avatar
James Raby
Just flush all the pipes out with a high pressure tap - and then let them dry
Put all back in place and should be ok
How often is the oil changed? - serious question
As said, short journeys WILL cause this problem due to the oil not getting hot enough
Old Jun 5, 2005 | 12:07 PM
Nice_aRSe's Avatar
Nice_aRSe
Not overly sure on last oil change.
Am going to change the oil this afternoon with the Silkolene Pro S 5W - 30 i brought few wks back
Old Jun 5, 2005 | 01:26 PM
James Raby's Avatar
James Raby
The one OILMAN recommended to me was Silkolene Pro S 10w-50
Old Jun 5, 2005 | 01:41 PM
Nice_aRSe's Avatar
Nice_aRSe
My mistake i have Silkolene 5W - 40 which oilman recommended to me
Old Jun 5, 2005 | 01:42 PM
James Raby's Avatar
James Raby
Ok, cool
Just didn't want you to use too thin a oil
Old Jun 5, 2005 | 01:46 PM
james_birch
5-40! nice!
im using the 10-50 race oil! .....highly canned motor!
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
155lee
Aug 14, 2015 11:21 AM
RsS2daz
Aug 14, 2015 05:26 AM
